Old 05-04-2008, 05:51 PM   #1
scotts62
One day...
scotts62's Avatar
Tubing benders????
Just wanted to see if anyone knows where to buy a tubing bender, like the kind for frame tube work and stuff like that... Any ideas??
Thanks, Scott
Scott
93 crew cab build
Project 62
Old 05-04-2008, 06:34 PM   #2
rotgg
Re: Tubing benders????
http://www.jd2.com/ there is one that is not to expensive you can also google tubing bender and 100s will come up
rotgg is offline   Reply With Quote
Old 05-05-2008, 05:26 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
http://www.mtechsupply.com/
here is where I purchased my first bender.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-05-2008, 06:13 AM   #4
abadsvt
abadsvt's Avatar
I bought a JMR tubing bender. I got just there manual bender with an 1 1/2" die with a 5" radius and i love it. I wouldn't mind upgrading to an hydraulic but wanted to make sure i like and use it enough. I absolutely love it. Here is where i bought mine http://www.tricktools.com/ . You really should buy this mount for you protractor though when you get a tubing bender. It is a necessity for doing multiple bends. Also you should get some lube for the dies so you don't wear them out. It helps preserves them and they are not cheap. Here is a pic on what i did with mine
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 05-05-2008, 07:56 PM   #5
scotts62
One day...
scotts62's Avatar
Man that looks good! Thanks for the info guys!
Scott
93 crew cab build
Project 62
