Old 05-04-2008, 08:24 PM   #1
clean71
clean71's Avatar
Exhaust Smell ???
Every time I drive my burb, I smell exhaust. If just the drivers side window is down I smell it. Both front windows down, I don't. I've gone through everything and can't find a leak, headers, header flanges, etc. I don't smell it when I'm at a stand still idling. So...I've come to the conclusion that it's the fact that I ran the new exhaust pipes straight out the back, right beneath the rear bumper, and that the exhaust is coming in through the not very well sealed back hatch.
Have any of you experienced this? Any other ideas? Just like to see what the experts might have to say before I cut the pipes and put some turndowns or 45 deg turns out to the side (would that help?). Thanks in advance for any input.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 05-04-2008, 09:09 PM   #2
nightmare
nightmare's Avatar
Re: Exhaust Smell ???
I've heard of this happening. You are correct in that when the pipes end, if they don't exit the vehicle completely, that there could be some sort of "drift" back into the passenger compartment. From what I remember, the newer vehicles require that they exit the vehicle completely, and when inspected, if they don't, they will fail the vehicle because of this, something about carbon monoxide poisoning. On a truck, I've heard that it's ok to dump right before the rear axle, or anywhere after the cab, because there is no possible way to have the exhaust gases get into the cab. With a 'burb, it's probably the same as a car. I would just add tips to the end, so that they exit past the rear bumper, and you don't have to worry about redoing a lot of the pipes.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-04-2008, 10:03 PM   #3
Wrenchbender Ret
My exhaust man recommends running the pipes out the sides behind the rear wheels on panels & burbs for that reason.
Wrenchbender Ret is offline   Reply With Quote
Old 05-05-2008, 05:32 AM   #4
stope4
you gotta clear the bumper 100%.
stope4 is offline   Reply With Quote
Old 05-05-2008, 06:00 AM   #5
ed2552
ed2552's Avatar
On new Suv's the exhaust MUST exit the side, due to the facts stated above. What i would do, cut it, do 45's and have some nice Auto parts store polished tips out the sides, looks good, sounds good
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
