Old 05-05-2008, 03:37 AM   #1
skydiver
Just a fan.
skydiver's Avatar
Can you tell what this is????
Hey Yall,
Noticed this connector hanging down from my engine. Can anyone tell me what it is? I have followed it up and it disappears into the harness somewhere. For sure it is not a vacuum line.
skydiver
Heres a picture. It is the black connector near the bottom.
skydiver is offline   Reply With Quote
Old 05-05-2008, 03:57 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Can you tell what this is????
was your truck originally a manual shift tranny, or was it always an automatic?
Old 05-05-2008, 03:59 AM   #3
Indyuke
I have the same exact connector on mine too, and I have no idea what it goes to. I'll have to watch this thread.
Indyuke is offline   Reply With Quote
Old 05-05-2008, 04:00 AM   #4
Longhorn Man
wait... after looking again, I am almost sure that goes to the electric kick down on the tranny... TH400?
Old 05-05-2008, 04:10 AM   #5
skydiver
Just a fan.
skydiver's Avatar
Just bought the truck last year. I assumed it has always been an automatic but after checking the option list it show that it came with a turbo hydra-matic code M49. Checking online this option shows that it is a Manual 5 speed. Now I am very confused as there are no signs that the truck was a manual. No hole for floor shifter or column. Its a 72 so not sure where the shifter would have been.
Old 05-05-2008, 04:23 AM   #6
berencam
berencam's Avatar
is it long enough to reach the master cylinder, and is there already a wire going to master? it almost looks like the low fluid light wire.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 05-05-2008, 04:28 AM   #7
Longhorn Man
turbo hydra-matic code M49 is a 3 speed automatic. That could be a TH350 or a TH400 in the trucks. Can you get a photo of the tranny pan?
The wiree going to the master cylinder would be brown
Old 05-05-2008, 04:29 AM   #8
Sinister
Between Trucks...
Sinister's Avatar
Looks like it could be oil pressure dummy light or water temp dummy light. What color is the wire? You could cross reference the wire color with a wiring diagram...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-05-2008, 04:35 AM   #9
berencam
berencam's Avatar
thought so, couldnt remember if it was black or brown, the little rubber piece on the end looked familiar.
Old 05-05-2008, 04:45 AM   #10
skydiver
Just a fan.
skydiver's Avatar
OK. Here are more picts. The wire is not brown but it does looks a lot like the brown wire going to mater cylinder. Makes sense that it would be some sort of warning light. I just took off the pan so took pictures of internal also.
Old 05-05-2008, 05:04 AM   #11
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Looks like a th350 to me. must be for a dummy light, oil or water temp. Do you have wires already going to these? The brake warning wire isn't long enough to hang down that low...well, I guess someone could have cut the loom.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-05-2008, 08:01 AM   #12
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I had one on my chevelle. As I remember, it works with the transmission, the throttle anti-dieseling-solenoid and the vacuum advance. The whole system is called the TSC (transmission spark control)
There should be a sensor like a dummy light oil pressure switch somewhere on the passenger side of the transmission. If you no longer have the solenoid on the carb, there is no need for the lead to the transmission.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 05-06-2008, 03:47 AM   #13
Indyuke
I was just thinking. The wire on my truck is unplugged and my back up lights don't work. Could it be the back up light wire?
Old 05-06-2008, 04:04 AM   #14
Dusty_case
Dusty_case's Avatar
I think that is your backup lights
1968 c10 250/3spd
Dusty_case is offline   Reply With Quote
Old 05-06-2008, 04:16 AM   #15
Longhorn Man
back up lights are wired up inside the cab, not underneath. That's why I was askin if it used to be a 4 speed, 4 speeds were plugged in underneath.
Old 05-06-2008, 01:49 PM   #16
GSFMECH
On the road
GSFMECH's Avatar
That's the TSC, transmission spark control as said above. That wire was connected to a switch in the side of the transmission. What it did was not allow the vacuum advance to work until the transmission is in high gear. When the truck was new there was a solenoid mounted on the intake manifold and the vacuum source was routed from the carb through it to the vacuum advance on the dist. I've always disconnected them, it will run better without it.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
