Old 05-05-2008, 03:42 AM   #1
rscam
Tank relocate with Jeep CJ tank
Got my CJ tank today and some people were interested in another option besides the Blazer tank. It fits 78-86 Jeep CJ and Scrambler. Its 15 gallons and measures as follows. The tank itself is 23 3/4"x17"x 10 3/4". The outer flange measures 25"x18 1/4" The total height if sitting on the ground is 11 1/2" and that is to the top of the sending unit frame that surrounds the sender. It has a 1" fill with 3/4" vent and 2 other small 1/2" ports that I don't know their purpose.The sender has a 5/16" supply and another 1/4" port that I think is a return. Here are some pics of the tank itself. I will post some pics of it installed also.
rscam is offline   Reply With Quote
Old 05-05-2008, 03:55 AM   #2
rscam
Re: Tank relocate with Jeep CJ tank
oops
Old 05-07-2008, 09:56 PM   #3
rscam
Some more pics.
Old 05-07-2008, 10:02 PM   #4
rscam
oops again
Old 05-07-2008, 10:08 PM   #5
HoupPhotography
WOW! I didn't even think...... That's a great idea, I have the stock one out of my '77 Jeep. It looks good.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-08-2008, 12:58 AM   #6
rscam
I'm quite happy with the height of it. I had to notch the one bed floor support above it by 1". If you could stand int being a little lower you wouldn't have to notch anything. It has 2 holes in it for mounting already. I had to drill 2 more on each corner so I could mount it without straps. I didn't want to dril in it but I couldn't find a good way to hang the front of it. If you decide to go this way it is only 15 gallons. If it were a daily driver you would have to fill up more often. I will only drive occasionally so its no big deal for me.
Old 05-08-2008, 01:18 AM   #7
70GMCer
70GMCer's Avatar
Would it be a problem with that 5/16" supply line for big engines? Isn't 5/16" for 6 cyl engines?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-08-2008, 01:29 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
Do you have pics of how you routed the lines and filler? Also, what did you do with those extra ports? Plug them? Thanks!
VA72C10 is offline   Reply With Quote
Old 05-08-2008, 02:00 AM   #9
rscam
I went to Autozone.com and found an emissions diagram. One port on the sender is not used and the other 2 small ones are for emissions cannisters so I plugged them. As for 5/16 It should be OK far a moderate V8. I don't have a fire breathing engine. I also looked at the sender and it said it was for I6 and V8 jeeps. They had 304 V8's so I figured it would be fine. Please correct me if I'm wrong. I haven't ran the filler yet but that is common to any tank.
Old 05-08-2008, 02:57 AM   #10
It looks good but I'm a worry wart. You probably need to add some straps to hold the tank up as the metal flanges of the tanks were not designed to hold the weight of a loaded fuel tank. You may cause a tear/brake in the tank just using thsoe bolts on the flanges for support.
It does look real good though!!
Old 05-08-2008, 03:23 AM   #11
HoupPhotography
Very good point! I would add the straps too.
Old 05-08-2008, 03:46 AM   #12
rscam
You talked me into it. I will add the straps. I wasn't sure but better safe than sorry.
Old 05-08-2008, 04:53 AM   #13
jkaylor68gmc
jkaylor68gmc's Avatar
looks good, what a great idea, those have to be cheap, especially from the JC WHitney.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 05-08-2008, 04:59 AM   #14
1tigers
Who did the welding on your exhaust.Hope you didn't much
1tigers is offline   Reply With Quote
Old 05-08-2008, 05:19 AM   #15
Grandpa's CST
Grandpa's CST's Avatar
Does the sender work with the oem guage?
Grandpa's CST is offline   Reply With Quote
Old 05-08-2008, 03:26 PM   #16
rscam
I am sorry 1tigers that this is not a concourse restoration. I just about didn't post the pic for fear that someone would point that out, but you did, Thanks. I am about a week from driving my truck. Not showing it. How far along are you?
Old 05-08-2008, 03:29 PM   #17
rscam
Grandpa as far as the sender is concerned I assume it will work because Jeep uses the same 0-90 ohms as GM. I had to add about a foot of wire to reach the tank. So I hope that won't change the restistance to much. We will see when I put fuel in it.
Old 05-08-2008, 05:38 PM   #18
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Great. Glad to see the jeep tanks work. Just another option out there now. Cool.
Congrats on the install.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-09-2008, 03:09 AM   #19
see ten
WTB this ad
see ten's Avatar
I used a CJ tank on my 66 4x4 that I used to own. Instead of straps I used the skid plate that goes under the tank to hold it to the frame. It's super sturdy and solid. As far as the gauge......it worked backwards on my 66 so E meant enough and F meant that you were Fu........well you get the point.
see ten is offline   Reply With Quote
Old 05-09-2008, 12:51 PM   #20
71tahoe
71tahoe's Avatar
F is for Fumes right?
71tahoe is offline   Reply With Quote
Old 05-09-2008, 01:57 PM   #21
Shaffer4
Strange Cousin From The West..
um.. wouldn't reversing the wires have worked?... then again... I am no electrician.
Shaffer4 is offline   Reply With Quote
