Old 05-05-2008, 04:31 AM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Hey carb guys. I.D. Help.
Out scrounging today and came across a 67 one-ton with a V-8. Carb is a carter wcfb. Not sure if it is original. My question is, how can i positivley id it with the tag mia? It has a bunch of patent numbers, but i can't find the 4 or 5 digit number on it. I can post pics if it may help. Any ideas? Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-05-2008, 04:34 AM   #2
berencam
berencam's Avatar
Re: Hey carb guys. I.D. Help.
2brl or 4brl? if its a 4 theres usually stamped numbers on the back of the choke part of the carb.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 05-05-2008, 05:02 AM   #3
too much stuff
Roadtrip!
It is a 4bbl. Thanks, I will check that out.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 05-05-2008, 05:50 AM   #4
clean67
Does it look like this,if so this is what i believe to be the right carb for 327.Both of my 327 trucks have the same.Also there was no 2bl on the 327 according to my lititure.This info only applies to 67,but may be correct for other years.Its not an easy carb to find for some reason.Let me know if numbers or pics will help.
67 Short Wide (My very first ride)
67 CST Custom Camper
67 Custom Camper
67 Suburban(Rust bucket)
clean67 is offline   Reply With Quote
Old 05-05-2008, 06:13 AM   #5
too much stuff
Roadtrip!
Clean67, that is the rochester 4 jet you have pictured. The one i picked up is a carter wcfb. It looks like it was used until 67. I will post some pics tomorrow
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 05-06-2008, 02:14 AM   #6
too much stuff
Roadtrip!
Pics...
Any ideas? It is an even bore.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 05-06-2008, 07:07 AM   #7
SBellew
Post all the numbers that are 3 - 5 digits. Some Carters have a 3-digit number instead of 4 and some have letter after them.
Or look here if you already have them in front of you.
~Scot
'77 C10
My build thread (Its a slow one)
SBellew is offline   Reply With Quote
Old 05-07-2008, 05:11 AM   #8
too much stuff
Roadtrip!
There is a number on the choke that doesn't cross in my book. aw549s. that is on the outside of the choke. Any other ideas on where to look? The base of the carb is rough cast, so no numbers there. I will keep looking.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 05-07-2008, 05:40 AM   #9
SBellew
Still looking. All I found so far is some info on the choke.
~Scot
'77 C10
Old 05-07-2008, 05:47 AM   #10
WorkinLonghorn
WorkinLonghorn's Avatar
http://cgi.ebay.com/ebaymotors/Carte...spagenameZWDVW
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-07-2008, 06:03 AM   #11
SBellew
The one on this page looks like it with a different choke. Cannot tell in your picture if the top part on yours is an adapter for breather or part of the carb.
~Scot
'77 C10
Old 05-07-2008, 06:39 AM   #12
too much stuff
Roadtrip!
I appreciate the help. We are getting somewhere, but i am guessing it is not original to the 67. It was used until then, but a truck would have a 2bbl according to my book.
Sbellew, definatley not a 348 as the choke identifies. Would already be pulled and sitting in my garage if it was...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
