Old 05-05-2008, 05:07 AM   #1
clean71
clean71's Avatar
Throttle cable removal??
Need to change out my throttle/accelerator cable on the 72. How is it mounted to the fire wall? Is there a nut on the back side or what? Can't see too well because of the firewall insulation but don't want to start tearing stuff apart that I don't need to. Thanks.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 05-05-2008, 05:24 AM   #2
chucks70
Re: Throttle cable removal??
The platic part that goes through the firewall clips on the inside. Squeeze the sides of the plastic and push it through toward the engine compartment. You may have to make the hole in the insulation a little bigger to get to the sides. I think its easier to get to if you disconnect the cable from the foot pedal first.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
