Old 05-05-2008, 05:42 PM   #1
FDEddie
FDEddie's Avatar
Gear ratio for LS swap??
Ok....Here we go! I'm sending my PCM to Speartech for the reprogram. I'll be
running a 6.0l LQ4/4L80E in my '72 short bed with 275/60-15 tires, 28" diameter.
This will be a driver, so economy is at the top of the list, but I don't want it to
be a dog either. The new truck/vans with this combo (3/4 and 1 ton) run a 3.73
standard. I was thinking 3.08. What do y'all think??
Thanks in advance for your input
FDEddie is offline   Reply With Quote
Old 05-05-2008, 06:39 PM   #2
killer71
killer71's Avatar
Re: Gear ratio for LS swap??
i had 3.08 gears in killer and i'd definit. recommend it especially for the hiway.....
i chose those gears just for the reasons you are gonna use your truck for!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 05-05-2008, 07:14 PM   #3
Wrenchbender Ret
Ive got 3.08 in my 70 stepside with 700-4R & 350 engine. It works real good but is sluggish at times. You can pull it down to direct drive & it pulls strong & still doesn't over rev.
Wrenchbender Ret is offline   Reply With Quote
Old 05-05-2008, 07:32 PM   #4
silverado84355
silverado84355's Avatar
Since your gonna have the overdrive I would go 3.73.
silverado84355 is offline   Reply With Quote
Old 05-05-2008, 08:15 PM   #5
LONGHAIR
3.08 is to high for an overdrive transmission especially with 28" tires. I would go with 3.73s but you might get away with 3.42 if you do most of your driving at highway speeds.
LONGHAIR is offline   Reply With Quote
Old 05-05-2008, 08:17 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I would say 3.42 would be a nice compromise. To me, anything under 3.23 would be too tall for performance at lower speeds.
I have a TrailBlazer SS with 4.10's and a 4L70 and the r's are certainly too high on the hiway for economy, but 3.73's wouldn't be tall enough either. I had 3.73's on my '01 Sierra C3 with a 6.0/4L60HD and it was "close" to the hiway sweet spot of 2k at 75-80mph, but still ran about 2300-2400 rpm IIRC.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-05-2008, 08:53 PM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
I agree with other guys. 3.08's with OD will be pretty gutless at certain speeds. The 6.0" will do better than the smaller engine, but I'd still go 3.42 or 3.73.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 05-05-2008, 11:45 PM   #8
68GMCCustom
or....put 4.10's in it and add a gear vendors overdrive to the tail of the 4L80...for a double overdrive 8 speed!
Kurt -
Old 05-06-2008, 12:37 AM   #9
killer71
killer71's Avatar
don't agree guys, sorry...the 5.3L 4l60e with 3.08's was gr
R.I.P.
Killer 71
10/26/07
Old 05-06-2008, 04:05 AM   #10
truckmanloco
It all depends on the transmission 4l60e or 4l80e,you cant go wrong with 3.73s its not to deep of a gear to kill your gas mileage, but still a good gear.
truckmanloco is offline   Reply With Quote
Old 05-06-2008, 05:14 AM   #11
ksbeatty
ksbeatty's Avatar
I have put a 700r4 with 4.10s in with 285's. I have not checked the RPM's yet but I can tell they are higher than I like. I don't want to steel the thread but do they make the 3.42 for the GM corp rear and a Dana 44 front?
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
