Crew/Suburban rear door panel question
I am looking to get some Silverado style door panels for my crew cab.
I have been told that on the rear door panels, the hole for the power switch is in the same place for the window crank on a manual door. Can anyone confirm this? I keep seeing power door panels but mine are manual and I intend to keep it that way. Thanks!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Re: Crew/Suburban rear door panel question
Anyone?
Bueler, Bueler...
I can measure the panels in the Suburban I have and give you the measurements if no one answers by tonight . Frank
Born and proudly residing in a Red State ! |
That would be much appreciated!
No big hurry though - it will be while until this goes anywhere. Just don't want to pass on a good set of door panels if they will work for me.
Sorry it took so long . Here are a couple pics with a tape measure . Let me know if this helps . Frank
Thanks for the pictures!
I am guessing that is from a '89-91 Burb? I am actually hoping to find a set from a '81-88 style. What I need to know is the distance the switch is from the edge of the door, top of the door. Looks like you took the measurement to the edge of the carpeted inserts. Thanks for the pictures though! *Edit - looks like the first picture answers that part of my question but I still need to know the distance to the edge of the door. But again, thanks for the picture.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 05-16-2008 at 05:23 AM. |
