05-05-2008, 11:12 PM | #1 |
Rice Killing 101
eaton parts where to find im flustered
i just recently discovered when a piece of wood (off my bed :\) fell off on the freeway and ive never seen such a beefy rearend in my life. well anyways i did my research and its either an eaton h052 or an h072 with 4.10 posi anyone kno where i can find sum parts of it cuz the posis burnt to all hell.. plz help :|
distrubin the peace since i got the thing and broke the origianl radio on 95.5 classic rock Ride: 1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi puttin in a 496 rebuilding trans need to rebuild diff :| need to start takin pics and start a project thread |
05-05-2008, 11:19 PM | #2 |
its all about the +6 inches
Re: eaton parts where to find im flustered
if its a 3/4 ton truck (C/20 or C/2500 GMC) then it is the HO52. Only one tons got the 72.
You are probably out of lck on locating a new locker, these rear ends have been obsolete for a long time now. |
05-05-2008, 11:22 PM | #3 |
I just went dana
05-06-2008, 01:10 AM | #4 |
Born Psycho
do the later model (73 up) 14 bolt GM corperate rear axle swap. it's a beefy SOB and parts are easy to find. GM still uses a version of it today. Dana 60s aren't nearly as strong unless you spend some serious coin on upgraded pieces, anything bigger than 35s and you'll see what i mean--you better have a good supply of spare axle shafts.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-06-2008, 02:54 AM | #5 |
Please explain what the rear needs.You just mentioned wood falling off the truck and the locker is burn`t.What`s exactly wrong with the locker?They are serviceable.Contact the manufacturer about service parts.You can`t but a newunit,but service parts should be available.The 14-bolt units can be made to work pretty easily.I have a later K/30axle set and I`m setting the 14-bolt aside in favor of an HO52/No-Spin.Napa has axle parts.
05-06-2008, 04:51 AM | #6 |
LET'S GO RACIN'
Inland truck parts might be able to help you. When i was rebuilding mine, that's where i found some parts.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY Rip El Jay RIP BOBBO'S MOM |
05-06-2008, 06:25 AM | #7 |
Just hang'n around
I have an Eaton 8 lug thing sitting by my garage. I've got the whole thing. If you are ever in Washington, you can have it. I might mention that this is out of a 71 3/4 ton. You might also check Randy's Ring and Pinion for parts.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. Last edited by Steelawork'n; 05-06-2008 at 06:27 AM. |
05-06-2008, 10:28 AM | #8 |
Rice Killing 101
thanks alot guys.. well pretty much the posi warn out to where its now a one wheel tire fire so i probably need to rebuild the diff and i'm still debating on whether to keep the 4.10 gears or buckle down and go to 3.73 gears instead
05-06-2008, 12:52 PM | #9 |
if you want anything higher than 4.10, then start looking to swap to another rear all together.
05-06-2008, 01:23 PM | #10 |
I had a No-Spin do the same thing right after I installed it.Just one wheel spins full-time,like a go cart,right?Worse traction than a bias rear.Almost impossible not to spin that tire.I just droe it home 5 miles,then back to yank it out.We couldn`t see any reason when we removed it.The only thing I can figure is the springs must be weak.It`s an indexed cog ring and really nothing to it and only one way to assemble.I`m sure they are available.If nothing else I figure the ones for the 14-bolt would work.I had another unit and just slapped that in.Whatever you do,don`t chuck that No-Spin.I`ll buy it or I`m sure someone will.
You can try to locate a Dana60 from these trucks with the 3.54s.I don`t believe even a 14-bolt comes any higher than 3.73.Someone correct me if I`m wrong.These "truck" ratios are fine with overdrive.
05-06-2008, 04:38 PM | #11 |
A detroit locker from a 14 bolt, bolts right in. You just have to use the 14 bolt axles. Last month I scored a new, in the GM box no spin, (detroit locker) for $200
05-07-2008, 03:40 AM | #12 |
Rice Killing 101
wow thats cheap 200 for a locker and im not ditching this rearend i was lookin for like 3.54 or 3.73 with a bolt on .64 overdrive
05-07-2008, 04:05 AM | #13 |
If you have a coil rear end, a 3.54 Dana out of a 68-72 3/4 ton 2WD suburban would be ideal. The axle should be a direct bolt on to coil spring rear end 3/4 ton pickup, since all 2WD suburbans had coils.
05-07-2008, 04:22 AM | #14 |
high-Tech Red Neck
You're axle is actually going to be a 4.56, or a 4.11 the HO72 did not come in a 4.10, it was either a 4.56 4.11 or a 3.90.
Now, Yukon Gear Makes gears for them still. And Randy'sRandy's carry's the Locker some times. They are a damn good axle, they were actually made by Eaton for GM, Eaton still has service parts listed for them. It would be worth your while to check em out. Even though they are a narrower housing than a 14 bolt, I feel as though they are a far superior axle. If you need any more info let me know.
"He used to be a pretty nice feller, now he's a welder!" |
05-07-2008, 04:44 AM | #15 |
It`s an HO52.The truck is a 3/4t.Isn`t 4.11 the Dana ratio and 4.10 the Eaton ratio?That`s what I`ve seen.
I didn`t see a listing for any Lckers under Yukon`s site.And...WOW!!!It`s cool Randy`s does,but jeezowiz!!!That`s alotta loot!I`d buy the 14-bolt unit for a couplehundred less and come up with some axles out of one of the millions of 14-bolts out there.
05-07-2008, 04:53 AM | #16 |
last I heard, the 3.90 was listed, but no longer avalible though the vendors listed.
05-07-2008, 05:15 AM | #17 |
i have an eaton in my 71 3/4 i just bought. how do i tell what model it is and what gear ratio it has. im new to 3/4 tons so i might need a little help.
05-07-2008, 05:27 AM | #18 |
that is the HO52 Corperate axle... commonly called the eaton. only the one tons had the HO72 The only sure fire way to know if you have no tach, is to remove the cover and count the teeth
05-07-2008, 09:00 AM | #19 |
Lurking Member
If I understand this correctly........I can use 14 bolt axles in my Eaton rearend with a locker from a 14 bolt?
JJ 72 GMC 1500 350 4 Speed, stone stock baby!!!!! 72 GMC K-2500 350TPI 700R4 For those who fought for it, Freedom has a flavor the protected will never know. |
05-07-2008, 09:02 AM | #20 |
Rice Killing 101
well ok im puttin like 600+ hp in the front backed by the new process 435 with the granny first so i just wanted to keep the whole axle i just reed replacement parts for the inner guts of the diff and probably like 3.54s
05-07-2008, 05:08 PM | #21 |
05-07-2008, 05:14 PM | #22 |
I have a bunch of eatons. The only gears I have are 4.10, 4.56, and 5.13. I run 4.56 in my Blazer 4X4 and my twd pu. Both have lockers. When I went on a 3500 mile road trip with the pu I put the economy 4.10's in to keep the rpm's down to 3600 rpm on the hiway. The blazer does ok with 35 inch tires, but while it appart for the rebuild its getting a 700r4, so it will becme my economy comuter.
05-08-2008, 09:05 AM | #23 |
Lurking Member
Thank you for the information, it's always nice to learn something new
05-08-2008, 01:02 PM | #24 |
Figure on shortening the axles,not just some need it,they all do.I don`t know of any 14-bolts that are a different width.It`s no big deal to do it.Figure on $500 +/- for the Locker plus cost of axles.They can be found used in junkyards.
05-08-2008, 03:14 PM | #25 |
high-Tech Red Neck
So then when you put in the 14 bolt carrier, you then can run a 14 bolt ring and pinion set? If so this would be awesome because the only gear ratio I can find to match my HO72 and a dana 60 is 4.56 and man that would be a fuel sucker.
