Old 05-06-2008, 03:32 AM   #1
SCOTI
SCOTI's Avatar
Chassis to Trailer Wiring?
I'm trying to repair the trailer wiring on my 74. There was a rats nest under the bed that just wasn't acceptable . . ....
I've got the wires from the truck sorted: L turn, R-turn, stop, & parking-lights. I removed all the hazardous splices that had been added through the years & streamlined the trucks wiring.
My problem is splicing in the trailer 'plug' wiring correctly. The plug (flat-4) has wires for L-turn, R-turn, stop, & a ground wire. My trailer has wires for: L turn, R-turn, stop, parking-lights, plus a ground.
Since the flat-4 plug has no specific wire dedicated for the parking-lights, how do I wire the parking lights from the truck to the flat-4 plug so that everything works correctly?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-06-2008, 03:38 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Chassis to Trailer Wiring?
Flat 4 wiring code
white ground
yellow left turn/brake light
green right turn/brake light
brown tail
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-06-2008, 04:51 AM   #3
SkylineNXS
SkylineNXS's Avatar
Normally witht he flat 4, the brake lights are really just the left and right turn illuminated simmultaniously, thats how the wiring normally goed for me. Idk why ur trailer has 5 though...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 05-06-2008, 05:06 AM   #4
SCOTI
SCOTI's Avatar
The wiring supplied w/the hitch was meant for 67-72's, so it's just a plug-in deal there. My 74 doesn't have the same chassis-to-bed wiring plug which is where the parking-light wiring has me confused.
My thought was to wire the park lights to the trailers tail/stop wire. The only lights that would work when the brakes are applied would be the ones w/dual elements right? The only lights that I know that have dual elements are the tail/stop lights on the trailer; everything else I would think has single elements.
The more I think about.... the more confusing it is.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-06-2008, 08:17 AM   #5
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
N2TRUX already answered your question above. You're confusing one thing - on your truck the brake lights and turn signals are the same thing. So no need for a separate signal path for them.
Therefor your four wires are : Left turn, Right turn, Parking, and ground.
On your trailer, you won't be able to use amber turn signals if it has them. You'll have to separate the left and right brake light wires and run them to the left and right turn wires coming from your truck. Then your trailer will have exactly the same lighting as your truck.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 05-06-2008, 08:28 AM   #6
motopatzo
motopatzo's Avatar
Try this link:
http://www.accessconnect.com/trailer_wiring_diagram.htm
motopatzo is offline   Reply With Quote
Old 05-10-2008, 07:40 AM   #7
SCOTI
SCOTI's Avatar
I had it wired right but found the wiring had been hacked farther up the line which caused my issues. I looked in my Chiltons book @ all the various wire colors & figured out "what was what" & spliced appropriate colored wire where it should be. Once that was corrected, I crimped & heat-shrunk all the splices & everything works like it should.
I'm going to put a new plug on my trailer & will test the connections befoe the end of the weekend.
Thanks to everyone & that link for trailer wiring is pretty handy to have.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
