05-06-2008, 04:20 AM | #1 |
Rear airbag guys... QUESTION!!
Im currently putting in my bolt-in c-notches, and was curious if anyone has just done away w/the original plate for the upper coil spring on the rear? I dont see the point in keeping it, and its just that much more metal to drill through, anyone?
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
05-06-2008, 09:31 AM | #2 |
Re: Rear airbag guys... QUESTION!!
I'd keep it. If your mounting your bag there, your putting the same stress on the frame as the spring was pressing. It was there for a reason, and your still using it for that same reason so I'd keep it. If it was one of those overkill ideas from factory then it should atleast give you a bit more piece of mind that your frame is strong, and oh well, not like it would be that much lighter.
05-06-2008, 07:02 PM | #3 |
I would agree with keeping it. Yes, drilling through it is a pain, but you only have to do it once per side.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-07-2008, 01:39 AM | #4 |
yea, just went ahead and bolted up the notch, thanks guys
