Old 11-04-2002, 01:43 PM   #1
70 longbed
Rear end and posi
I have a 70 longbed with coil spring and sinle lunger. I am looking for a 12 bolt with 3:73 rear end. Someone offered me a 73, 10 bolt , rear end with leaf springs and 3:73 posi at a good price. Will this fit, without any major modifications. What might the mods be, and what might the cons be to the project.
70 longbed is offline   Reply With Quote
Old 11-04-2002, 01:52 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You will need to get a rear end mount set for the controll arm trucks and an adlustable pan hard bar set for it also. You will have to cut the mounts off of the 73 rear then weld the new ones on in their spots making sure to center the rear and get the correct 2 deg. pinion angle befor you weld it. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-04-2002, 01:53 PM   #3
JimKshortstep4x4
Smile
Outside of the 12 bolt being a better rear end, (stronger), the 73 will take some mods to install. The shock mounts are different and adapting the leaf spring rear end to a trailing arms setup could be a little more serious. I would post on the parts board for a ring and pinion and then buy a new posi unit if it were me.
Otherwise, sometimes a complete rear end is available with posi's
but most need rebuilding anyway and the rebuilding cost can equal the cost of a new one.
Good luck!
Jim
Old 11-04-2002, 01:56 PM   #4
crazy longhorn
Fabricate till you "puke"
There is a saddle, & track rod kit to put that in, just requires a little welding. You will also have 5 lug axles. let me see if i can find the kit...... http://www.classicperform.com/produc...ersion-Kit.htm
crazy longhorn is offline   Reply With Quote
Old 11-04-2002, 02:08 PM   #5
70c10
67-72 Addict!
70c10's Avatar
One of our board members had one for sale recently in Georgia for $300 complete. Don't remember the name. I just ordered a new Posi unit from www.tomsdifferentials.com for $280. New bearings and races were an additional $32 plus $18 shipping.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
