Rusty but Trusty
replacing upper control arm shafts
on a 67 1/2 ton, can you replace the upper control arm shaft and bushings with out separating the upper ball joint from the spindle?
Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
Restoration Virgin!
Re: replacing upper control arm shafts
I think you'll have to remove them...if you need shafts...check out my Parts for sale....http://67-72chevytrucks.com/vboard/s...d.php?t=289716
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
I don't see why not. Just make sure you take the weight off the upper end. Are you having problems seperating the upper ball joint?
That's how I did mine. Just watch out and make sure the coil spring has no load on it. When mine is jacked all the way up it unloads the coil spring all the way. Besure you get the measurement correct when you reinstall the caps. The service manual has the correct measurements in it. Also keep the alignment spacers in order. Break loose the caps before you take the control arm mount bolts off.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
Yes you can replace the shaft and bushings without breaking the upper joint loose.I have done it many times. Just make sure your jack stand or jack is out under the lower ball joint as far as possible.This will takethe pressure off the upper control arm.you can remove the 2 nuts that hold the crosshaft to the frame,and then just swing the arm out where you can work on it.
Hollister Road Co.
Sorry guys but thats a brain injury waiting to happen. if that spring unloads while you have the upper shaft undone .... just sign a donor card first. Get the proper tool and compress the spring then do your work. Autozone and others have loan a tool programs.
Rusty but Trusty
I don't have a problem separating the upper ball joint or removing the spring. Just looking for the most efficient way. Don't want to do something if its not needed.
Thanks for all the replies. Lee
