5 lug rear axles
I'm junking a 76 Chevy big 10 that I took the front disc's off for my 65 (Note: I think the spindles are larger than a standard 1/2 ton but not sure)
My questions is, does anyone know if the rear 5 lug axles out of the 76 big ten 12 bolt rear would swap into the 12 bolt rear in my 65? That would save buying the axles out of CCP or somewhere else. The rears measure close to the same, but not sure if they would actually install, has anyone tried this? I've got the scrap man coming tomorrow afternoon to get the truck, but I'll have him wait if they will work. Thanks guys!
65' Chevy C10, Short Step ![]() 75' Chevy Big10 1/2, 1 time pull truck, now parts truck 02' GMC 2500HD 8.1L 4X4 ![]() |
Re: 5 lug rear axles
Anybody got anything on this?
![]() Join Date: Apr 2008
Before the JunkMan cometh, I'd yank the whole rear axle out from under, but if you don' want to go there, at least pull the axles, and full brake sets. If you swap them with the full brakes, I think the axles may just work. But if it's long gone and you could have used 'em you'll be sorry....
![]() Dan
1966 Chevy Suburban 'Gater - Shop Truck - 350/turbo 350 Power Steering, B&M Floor Shift, Dual side dump exhaust Chrome Rally 6 lugs. (((XM)))tunes! 1965 Riviera 425 - Luxury Muscle - Fully Factory Loaded. All power, A/C, Custom Interior, Guidematic Dimmer, AM/FM - etc, etc 1966 Corvair Corsa Turbo - Factory Sport Model - Quick steering, F-41 HD suspension, Positraction, Tele Wheel. |
#4 | |
Yep, their I believe 3/4 inch on each side wider. I've got one under my 66 tho. Only issue is mounts for it, which isn't a big deal and then if your gonna lower the hell out of it, I ran into issues with it hitting the bed side at the spot welds.
Council of the Elders
To repeat what others have said, the axles will not swap over. Replacement conversion axles are available or have yours redrilled and the center registers turned down. It is probably safer just to get the replacement axles. A 71 or 72 differential is a perfect swap except for the extra 1 1/2 width.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
Thanks for the info guys, saved me many hours of disappointment. Also, Billydonn, your truck is my wallpaper at home, nice truck!
I am glad to help a gentleman of such refined good taste!
