05-06-2008, 06:01 PM | #1 |
2WD Jimmy
Radio Delete plates
Anyone know where I can get some really nice factory radio delete plates?
TIA, Tom |
05-06-2008, 06:08 PM | #2 |
Re: Radio Delete plates
plates as in plural? doesn't lmc sell them, or are you wanting nos ones.
05-06-2008, 06:26 PM | #3 |
Gone Fishing
If you watch the parts board they pop up from time to time
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
05-06-2008, 06:33 PM | #4 |
I can't find them at LMC... what would THEY call them?
'70 C-10 Short/Fleet 350 In the family since new and more than 300K on the odometer! |
05-06-2008, 06:47 PM | #5 |
Active Member
If you have some tools and are handy with do it yourself stuff, you could make your own. Should be fairly easy to make one.
I made one out of wood once. I also toyed with the idea of making one out of aluminum and epoxying two flat head bolts on the back to line up with the volume and tuning holes then use couple of large washers for mounting. Then I found my original one that I had lost... |
05-06-2008, 06:50 PM | #6 |
i just assumed they had them, guess they dont i looked for the first time. Guess its a good thing i grabbed the one out of my wrecked pickup.
05-06-2008, 08:05 PM | #7 |
bummer
05-06-2008, 08:11 PM | #8 |
become a supporting member. then post a WTB in the parts section. You might be suprised what you come up with.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-06-2008, 09:16 PM | #9 |
On e-bay a guy sells one that you can mount 2 guages.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
05-06-2008, 09:29 PM | #10 |
Tot Roddin'
I agree with a couple posts above... either check the parts board, or become a supporting member and place a WTB ad.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
