Will it run today?
Help, is there a solution??
My passenger window is stuck in the "up" position, I believe the regulator is rusted and now frozen. I tried for a couple of hours yesterday to get it lubed enough to roll down, so I can pull out the vent window and the regulator.
Is there a way to swap out the regulator with the window "up"?
Jaws, the 1971 Chevy Cheyenne Longbed. She's big, grey, and has an insatiable appetite! |
Re: Help, is there a solution??
If I remeber correctly thats how I pulled mine off with the window up.I don't think theres room to pull the reg. out with the window down.
77 swb starting all over again. |
Gettin By on Gettin By
If its stuck, and you are planning on replacing it anyway, just get a big hammer, chisel, and vise grips and rip the regulator controll arm out. Not sure if thats it's offical name, but the shaft where the roller attaches to.
That should drop it. Or just put a hand on the inside and out side of the glass, and wiggle it down. Worked with mine.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
![]() Join Date: Aug 2005
x2 on the vice grips. That's how I got mine out. Not fun at all.
its all about the +6 inches
pull the door panel off, and squirt a butt load of PB blaster in there on the tracks and everything. It probably doesn't even need replaced, just lubed.
Hopefully Longhorn Man's suggestion will work as getting the regulator out with the vent window assembly in is pretty impossible.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Agree
Longhorn trumps alot that most, and everything that i say.
Will it run today?
Thanks everyone, I'll pick up some PB Blaster tomorrow and give it a shot. I've tried lithium grease and WD40, but that was a gargantuan waste of time.
How does the glass slide off of the regulator? Does anyone know of a diagram? Thanks again for all of the help! David
Will it run today?
Found this, supports what you guys are saying. Wish me luck...
http://67-72chevytrucks.com/vboard/s...ad.php?t=83475
