Old 05-07-2002, 05:12 PM   #1
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
Post 700r4 ?????
I've been thinking about putting this transmission in my truck. I was wondering what changes I would have to make. Can I still use my stock shifter or do I have to go to a aftermarket floor shifter? What about crossmember and driveshaft? what needs to be changed? I know some of you guys are using this in your trucks, what tips can you give me? Thanks.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 05-07-2002, 05:15 PM   #2
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
Post
Well first tell what you've got and we can go from there. i know on my 69 with a th400 you need to either move the x-member or buy a new one, get a TV setup, linkage for the new tranny, and the driveshaft has to be shortened/balanced. Other than that umm i cant think of much else...
69 Custom 20, 396BB,Longbed fleetside.
New Oak Bed With SS strips... damn nice.
Edelbrock performer RPM-O, Edelbrock 750Carb, Headers, HEI, 2 40" glasspacks.
Stereo: Classic-style tape deck/radio, 2 6x9 Cerwin Vega's in doors, 2 10" Neo subs under seats, 1 900 Watt amp.
SN= Ares220
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 05-07-2002, 05:18 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Since you are running a big block, it'll be VERY expensive to do and have it hold up. Your best bet is to hook up with Jegs, summit, maybe TCI. They will give you the bad news in acurate numbers.
As far as truck mods, Chances are you will need driveshaft mods, and a real good balance job. Let them know it is fo an overdrive aplication.
The crosmember will need moved.
Some one n here said yur stock (automatic) shifter will work, but you might not be able to get to first gear.
You will need to get a T.V. cable and asosiated hardware. Best bet to have a pro set this part up. Make sure they do it with oil pressure guages and stuff, if it is not adjusted just right, your tranny will become a very expensive paper weight in short order. (like in 2500 miles)
Some thing to think about, esp if your current tranny is fresh, is the gear vendors over/under drive. They are awsome and indstructable. here's the link...I'll let them expalin it; http://www.gearvendors.com/commercial.html
The 700 is an ok tranny when everything is stock, but it does not loan its self to swapping very well. A very picky piece.
I have been unimpressed with pretty much all the rear wheel drive over drive trannies made by the big 3. The ones they put in the normal vehices pretty much suck. (excluding corvete...whenre they beef it up cuz they know about the broblems) Ford ones blow, chevy ones blow, and dodge came close, but no cigar. And the 5 speeds in most light vehicles are a joke. Ever wonder why 3rd gen Cammaros never had 5 speeds? Cuz the T-5 couldn't even live behind the 305 with a person who drives it hard...nor the ford's 302. Get on any mustang or camaro board. They know it all to well.
Sorry, I'm rambling again.
[This message has been edited by longhornmail (edited May 07, 2002).]
Old 05-07-2002, 05:25 PM   #4
71HUGGER396
Post
My truck now has a 396, th400, and a one piece driveshaft. This is the way that I bought it. The engine is going in for a rebuild next month. I was going to freshen up the th400 also, so the guy that is doing the engine suggested that I switch to 700r4.
Old 05-07-2002, 05:40 PM   #5
Longhorn Man
Post
Get a second opinion from a got respectful tranny shot that knows high performance stuff. They will tell you what a 700 is rated for.
Are you going for a stock rebuild on your 396, or are you putting some speed goodies in it?
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
