Old 05-07-2008, 12:20 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Steering column help needed
I am installing newer seats that put me too close to the wheel for my comfort. I am interested in installing a shorter tilt column. Not Interested in shortening a factory or van tilt. I have been looking at the ididit and flaming river columns and noticed the 3/4"DD and 1" DD. Supposedly the 1" is better and is more available, but it looks like ours are 3/4"? I'd really like a 28" if that will work, but 30" would be better than the 32" that I believe is stock. Any advice? Anyone do this? Any clearance issues to look out for with the dash? I tried the search, but i stink at it our it stinks because i never find what i'm looking for.
Last edited by VA72C10; 05-07-2008 at 02:58 PM. Reason: People keep telling me about factory columns and i am looking for information on aftermarket ones.
VA72C10 is offline   Reply With Quote
Old 05-07-2008, 01:42 AM   #2
john
member #16
john's Avatar
Re: Steering column help needed
Heres a how to by putter to shorten your own column. Check out the FAQ section sometime.
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
john is offline   Reply With Quote
Old 05-07-2008, 05:31 AM   #3
VA72C10
VA72C10
VA72C10's Avatar
I appreciate that, and have checked out the FAQ several times. but i want a tilt and a column for floor shifter and have an automatic non tilt right now so unless someone can show how to make an auto non-tilt into a manual tilt, i still need some help. Thanks!
Old 05-07-2008, 02:27 PM   #4
Huck
Huck's Avatar
Any of the stock 69-72 columns use an intermediate shaft that attaches to the steering box. This shaft is fluted in that you can drill out the plastic pins and compress it ---once done, you can then move your steering column forward into the dash--really makes no difference between tilt or non tilt. Either will work. You can convert an automatic tilt to a floor shift tilt but you have to disassemble it and close the hole from the shift stalk. Don't believe replacement floor shift tilt parts are available for substitution. Huck
Huck is offline   Reply With Quote
Old 05-07-2008, 02:57 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the info. Well, i am actually figuring on aftermarket as i see the paintable tilt columns with billet dress up kits for only 250 or so....much less than a used factory tilt and brand new versus a potentially loose used column. So I guess my question is about 28" or 30" aftermarket columns only.
Old 05-07-2008, 05:43 PM   #6
haysonj
haysonj's Avatar
This is mine paintable Ididit
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
