Old 05-07-2008, 03:44 AM   #1
fatboys69
fatboys69's Avatar
Starter & Flywheel Question
Whats the normal "spec" for clearance between starter and flywheel. Min is a little noisy and I put in a 1/32" shim and didn't help much so I installed a
1/16" one and it is a little better but still doesn't sound quite right. Fly wheell & starter are about 3 yrs old. Any help / info is GREATLY APPRECIATED !!!!
Also what is the correct timing for a 69 with a 69 model 350ci motor.
fatboys69 is offline   Reply With Quote
Old 05-07-2008, 03:55 AM   #2
El Jay
Gone to greener pastures
Re: Starter & Flywheel Question
According to the "Chilton's" sitting next to my desk; Manual is TDC, auto is 4B.
Hope that helped.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-07-2008, 04:04 AM   #3
fatboys69
fatboys69's Avatar
El Jay, Thanks for the info, it helps gonna check it tommorrow.
Old 05-07-2008, 06:14 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
With the starter gear engaged in the flywheel, put a large paperclip between the flywheel gear valley and the starter tooth peak. That is about the same size as a .022 wire gauge. That is what you want for a general starter to flywheel clearance.
piecesparts is offline   Reply With Quote
Old 05-07-2008, 02:54 PM   #5
fatboys69
fatboys69's Avatar
Thanks For The Info !!!!!!
