Old 05-07-2008, 05:58 AM   #1
aventur1
aventur1's Avatar
Billit Dash--Polish Out?
Will these scratchs polish out?
aventur1 is offline   Reply With Quote
Old 05-07-2008, 06:06 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Billit Dash--Polish Out?
Yes they will, BUT you will be best to do it with wet and dry sand paper first and then poish it with a power polishing wheel on a hand grinder or a buffer on a stand.
Take a 400 to 600 grit wet and dry sand paper and use WD-40 as a wetting agent. Start to remove the scratches with the corse paper. Then step up to a 1500 grit paper using the wd-40 all the time. Finish with a 2500 grit paper. Then start the final buffing and polish with the different grades of material and buffing wheels. It will surprise you that it is easier than you think.
piecesparts is offline   Reply With Quote
Old 05-07-2008, 06:11 AM   #3
Arad68
Trucks N Tranzams
Arad68's Avatar
Yes they will, but it wil take some time. Use 800 grit wet or dry wet sanding to get the scratches smooth using a stiff sponge to avoid finger grooves. Progress all the way through 2000 grit (wet sanding ) and then polish it with mothers or a comparable metal polish and a microfiber cloth.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-07-2008, 06:19 AM   #4
aventur1
aventur1's Avatar
Ok, looks like I have some work to do!!!
Thanks!!!!!!!!
Old 05-07-2008, 03:48 PM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
Looks like somebody had a tach strapped to the column!
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 05-07-2008, 04:36 PM   #6
aventur1
aventur1's Avatar
I think your right. I got this as in a box of mics. parts, kinda a grab bag of small parts, so I just want to clean it up, although I do have a stock dash with Dolphin gauges and going to use it instead of this billit grill. This one has the smaller gauges at a angle, most I've seen are across the bottom.
Old 05-07-2008, 09:43 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-07-2008, 10:14 PM   #8
matthufham
paint it
matthufham is offline   Reply With Quote
