Old 05-07-2008, 07:28 AM   #1
Luvlegs
Luvlegs's Avatar
Melting shoes? Possible? or what?
Pulled the first rear drum tonight (picked up new pads and shoes, 72) - it looks like something melted in there! It's taking forever to get it cleaned... brake cleaner didn't touch it, so I tried good ol' laquer thinner... it was like stirring cold, hot glue. 3 rounds with oven cleaner and it's starting to come around.... what a mess! Any ideas? From the pics, it looks like the edges of the shoes but that might just be where it's building up. The drum came right off real easy - first one in 40+ years of trying It only has a very slight ridge at the edge closest to the frame. My very first thought was rear end lube because it smelled like it when I first pulled the hub but it sure doesn't look like it.
On a side note, the cylinder looks nice and dry and I'm never down any fluid so should I just leave it alone or ????
As always, thanks for any input.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 05-07-2008, 07:44 AM   #2
Blue_71
Bloo
Blue_71's Avatar
Re: Melting shoes? Possible? or what?
hard to say without actually seeing it in person, but that looks like the nice concotion you get when you mix brake dust, heat, and rear end lube
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 05-07-2008, 12:19 PM   #3
soba_03
soba_03's Avatar
I would have to agree it looks like maybe axel shaft seal gone bad. Looks like burnt grease or oil. Actually had the same problem with 91 Silverado and haven't had it on my 68 but it looks the same.
GOOD LUCK FINDING PROBLEM.
soba_03 is offline   Reply With Quote
Old 05-07-2008, 12:56 PM   #4
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
I have to agree with the guys. I've never seen anything like that.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 05-07-2008, 01:11 PM   #5
bad6772
Official Site Guitar Shredder
bad6772's Avatar
WOW........and imo i would replace the wheel cylinder.....your already there....and they are relatively cheap.....
bad6772 is offline   Reply With Quote
Old 05-07-2008, 01:55 PM   #6
soba_03
soba_03's Avatar
Well you could look at it as a blessing, that brake overhaul that you could never justify... It's looking at ya... all you need is a spring kit, new wheel cylinder, you already have the shoes, pull the axel shaft, and whille your at it clean and paint the backing plate..... I remember it was PITA to get it cleaned up....it was under warranty so All I had to do was throw on another set of shoes and drive it to the dealership....
good luck..... OR you could go disc!!!
Old 05-07-2008, 02:48 PM   #7
Luvlegs
Luvlegs's Avatar
Guess I'm going to give the truck a new name but I ALREADY have a BOAT (Bring On Another Thousand...) and THAT'S already living up to it's name ... grrrrr one of these days, one of these days....
Thanks for the input everyone.
1972 C10 L6 3OTT
