Old 05-07-2008, 07:32 AM   #1
lyrikz
PITbut
lyrikz's Avatar
Slam specialties RE7's?? Still made??
I want to buy a set of rear bags. I have read alot of good things about the slam specialties RE7's with internal bump stops. I cant find them on *****************. Are they still selling these bags?? Anyone know where i can get em???
Any recommendations on which ones i should run.
71 stepside. Going to do some super light towing. I was thinking the Re7s would be best. Recs?
lyrikz is offline   Reply With Quote
Old 05-07-2008, 08:31 AM   #2
los-lowrider
los-lowrider's Avatar
Re: Slam specialties RE7's?? Still made??
Here you go:
http://www.*****************/SlamSpec...SinglePort.php
Best Regards from Germany!
www.los-lowrider.com
los-lowrider is offline   Reply With Quote
Old 05-07-2008, 06:53 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by los-lowrider View Post
The re200's are the Re7's???
Old 05-07-2008, 07:55 PM   #4
jimmydean
jimmydean's Avatar
RE7 is a 7" RE200. Where as an RE6 is a 6" RE200. I think you are getting caught up on the name scheme.
RE = 200PSI
HE = 400PSI
XS = 600PSI
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-07-2008, 07:56 PM   #5
lyrikz
PITbut
lyrikz's Avatar
RE = 200PSI
HE = 400PSI
XS = 600PSI
ahh, thanks. so an Re7 should be good for my truck right??? 2wd stepside???
Old 05-07-2008, 08:15 PM   #6
jimmydean
jimmydean's Avatar
Yes, the RE7 is a great setup. That's what I used on my last truck and depending on what rear setup I go with, it will likely be what I use on this rig as well.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-07-2008, 08:18 PM   #7
bedsled71
bedsled71's Avatar
it also depends where you mount you bags. because the dif. diameters also mean different lengths and usable stroke.. here is a link to check out the stats. http://slamspecialties.com/s_compare_fv.html
bedsled71 is offline   Reply With Quote
Old 05-07-2008, 10:01 PM   #8
lyrikz
PITbut
lyrikz's Avatar
Mountin in the usual spot, where the springs are.... I ordered some plates also.. The guy rec: it on the phone.
Old 05-08-2008, 01:51 AM   #9
madkaw_16
madkaw_16's Avatar
i can vouch for the re7's, they're amazing. I've also heard good things about the new dominator bags. Anybody using those yet?
madkaw_16 is offline   Reply With Quote
