brown bread and seat install -
I am putting brown bread down (bquiet extreme) on the floor of my '67 and was wondering about anyone that has done this, did they install the seat over the insulation, or cut out a footprint for the seat and install it metal to metal??
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
![]() Join Date: Jan 2008
Re: brown bread and seat install -
ive always cut around the mounting point, so the frame would sit metal to metal. others may suggest other wise
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
![]() Join Date: Apr 2004
I cut around the seat .
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Project underway - finally.
Wha? I hope you don't mean you cut around the whole seat. I think cutting around the mounting points is wise, but I am sure you could do it the other way if you wanted for some reason. The only bad thing is that the edge might come up over the bracket if the cut is too rough.
1972 GMC Pre-resto... awaiting allocated funding. |
I didnt cut out for the brackets, It shouldnt make any difference really either way you go.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
#6 | |
Active Member
![]() Join Date: Feb 2000
I used brown bed also on my Chevy, and just cut around where the seat frame met the floor.I thought I would have a rough time running the bolts down otherwise. I used some cheap insulation from Lowe's on my GMC daily hauler. Big difference. Ya get what you pay for.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
Tot Roddin'
I wouldn't see where a major difference would happen either way, but it sounds like the majority of people are actually cutting around the seat mounts.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 05-08-2008 at 04:01 AM. |
