Old 05-07-2008, 05:39 PM   #1
Premium72
Premium72's Avatar
questions about 350 mounts..
lookn to get this engine from a guy off craigslist. are there any differences in mounts on a 93 350 from a camaro then a 350 from a 82 seira? will this fit in my truck? help me out fellas. i didnt think there where any differences..thanx.
Premium72 is offline   Reply With Quote
Old 05-07-2008, 06:07 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: questions about 350 mounts..
It will bolt right in. The mounts are different for different applications, but all of them bolt to the block in the same way. The dipstick will be on the passenger side on the newer motor.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-07-2008, 06:46 PM   #3
Premium72
Premium72's Avatar
yeah my exactly what i thought. just wanted to make 100% sure. thanx.
Old 05-08-2008, 04:39 AM   #4
Green Machine
Green Machine's Avatar
Check to see if you can mount a fuel pump on the 93 block, some are not drilled, if you run a clutch, make sure the bolt holes are there to mount your linkage also. You will also need a flywheel for a one piece rear seal.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
