Old 05-07-2008, 09:32 PM   #1
68c10guy
68c10guy's Avatar
Wiper blades
how do i get the wiper blades off my truck the PO put them on misalligned
68c10guy is offline   Reply With Quote
Old 05-07-2008, 11:41 PM   #2
Sammy
Re: Wiper blades
Flex the blade arm level. Use something flat (non maring) maybe lg screwdriver covered in a rag & pry up next to the shaft. Thats the tricky part without damage to cowl.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-08-2008, 01:25 AM   #3
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Wiper blades
x2....And keep a hold of it so you don't launch it, and then it lands on the Hood.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 05-08-2008, 01:51 AM   #4
cobb_ben
cobb_ben's Avatar
Re: Wiper blades
Yup pretty much pry them off they have a clip that will ingage below the arm that has the arm that the arm goes on. Sometimes it catches on there, you might have to use a screw driver to pry the clip while you pry the arm up. Make sure to run the wipers so that they rest in the proper down position. Cuz the wiper arms can go past the "probper resting position, thats probally what the PO did. It can be frusterating!!! I just did this.
'69 Chevy C10
400sb-350 crank 400 destroker!!! 377
2.02 dart pro1 alum.heads
msd, holley db
hooker pro-comps-3in exh.
3 spd. saginaw-3.73posi
Flat Bed...want Reg bed...trades?
cobb_ben is offline   Reply With Quote
Old 05-08-2008, 04:17 AM   #5
68c10guy
68c10guy's Avatar
Re: Wiper blades
awesome thanks for the help looks like prying is my solution.
Old 05-09-2008, 01:44 AM   #6
Sammy
Re: Wiper blades
There is a special tool they make for these I seen years ago. But just like the battery clamp tool no one ever used em. How often you would need to remove em.
