Old 05-08-2008, 02:43 AM   #1
83burban
62 Frame off Resto
Hey everybody, been on the board for a little while now and have learned tons about these old trucks. I figured that I would share my project with everybody and while I am at it get some questions answered. I am doing a frame off, nut and bolt restoration of a 62 C20.
The truck was originally a 62 C20 that I gutted and stripped only to find a bent frame, tons of shody fab-work, some rust in the roof and the pillar, and lots of body work needed.
I started to look for a donor truck to replace the torsion bars and frame. I found a 64 C10 with tons of factory options and for only 250 it seemed like a hell of a deal. It came with factory power steering, power brakes, and auto trans cross-member. The frame is in great shape and from what I have read some pretty rare factory options.
The plans for the build are this:
1) 4.5 inch drop front, 5 in the rear
2) Disc brakes front, Drum rear...keep it six lug to keep stock wheels
3) Keep power assist steering and power brakes
4) Keep the interior looking stock, but fixed up with custom cab options
6) Lava Orange, Creme accents and roof, Artillery style rims and white-wall tires
7) 454 (eventually 496) backed by a th400 and a 12 bolt
Questions:
1) I have read (and measured) all the cab mount locations and they are different between the two frames. I know that my body will not bolt up, so can I just cut the old body mounts off of the 62 frame and put them on the 64 frame, or will they still be off? The rear lines up if memory serves right. The bed is taken care of, since I will use the cross-supports from the 64 instead of the 62.
I attached a couple pictures of the donor truck frame. I hope to have this done in 4 months - and will update the thread as I go along. Thanks for all the help guys.
83burban is offline   Reply With Quote
Old 05-08-2008, 05:53 AM   #2
62 short step
62 short step's Avatar
Re: 62 Frame off Resto
Welcome! Sounds like you have a good solid plan on your truck. Good luck with it!!
62 short step is offline   Reply With Quote
Old 05-08-2008, 06:07 AM   #3
joe231
joe231's Avatar
welcome!
CHEVY ONLY
Old 05-08-2008, 07:11 AM   #4
Captainfab
60-66 Nut
Welcome to the board from Idaho!
Questions:
I would just drill holes in the cab floor to line up with the brackets on the '64 frame. The front body mount on the bottom of the cab is the same from '60 to '66. The rear mounts will line up.
2) Can I use a stock style master cylinder with the disc brakes (single outlet) and just tee it off - 1 to the front and 1 (adjustable prop valve) to the rear?
I wouldn't recommend it. The later model dual resevior masters should work with the original booster. I haven't actually done it, but it should be doable.
Old 05-08-2008, 07:23 AM   #5
83burban
Thanks for all the welcomes guys.
Captainfab:
1) I have heard about drilling holes in the floor to line the front up, but aren't the factory holes in the cab recessed? Wouldn't that make the mounting place stronger? I am concerned that if I just drill two holes that it might stress the floor, maybe I can just use some large washers or something to distribute load.
2) I do plan on power brakes, just liked the looks of the original master cylinder. If I were to put a corvette, disc/disc master in would it bolt up? I want to use the stock booster so that I don't have to purchase the CPP one. I do not like how the later model stock ones look in these old trucks.
Thanks for the help, I ask a lot of questions to start because I purchase all my parts before I start to work on bolting anything on, that way I can hit the project hard for a couple days and gets tons done rather than having to stop and wait for that one damn part
Old 05-08-2008, 07:34 AM   #6
Captainfab
60-66 Nut
Captainfab:
Why not just transfer the recessed reinforcing plates from the '64 cab to the '62 cab in the new location.....or even just move the ones in the '62 cab and then patch the original holes.
I haven't installed a corvette master on an original booster, but I do know that the corvette master uses a short pushrod between the booster and the master. You might look on your original to see if it is setup that way.....I just can't remember if it is. The mounting stud spacing will be the same. Hopefully someone who has done this will chime in
Old 05-08-2008, 03:05 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Welcome to the board from Mid-MO!!! Great looking project, good luck!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-09-2008, 02:00 AM   #8
scotts62
One day...
scotts62's Avatar
from OKC!! Good looking project keep us posted on the progress!!
Scott
93 crew cab build
Project 62
Old 07-07-2008, 12:17 AM   #9
83burban
Well, its finally time to bring this thread back to life. I have gotten alot of parts back from the powder-coater and blaster. Haven't had much time to work on it, but over the past week or so I have been slowly piecing the frame and suspension back together. Next phase will be completing the steering, and the rear axle assembly, making this a true roller followed by dropping in the engine and trans.
Anyways, enough talking here are the pictures. Comments welcome.
Old 07-07-2008, 12:20 AM   #10
83burban
More Pictures - WE all love pictures.
Old 07-07-2008, 12:25 AM   #11
83burban
And finally a few of the cab itself. Just a hint...U-haul 6X12 trailers are 1" too narrow the bring the cab out We ended up having to lift it out and over the rail and I managed to damage the cab a little bit. Oh well, nothing I can do about it now.
Old 07-07-2008, 12:27 AM   #12
83burban
Also...It seems that for some odd reason the previous owner removed the radiator mount cross-member completely and kept it for himself. Can somebody please send me a picture of how it mounts up exactly? I am also looking for that particular part if anyone has one from a truck they are parting out. Thanks
Old 07-07-2008, 06:25 AM   #13
63sbssbbw
UCA63
63sbssbbw's Avatar
Looking awesome 62
Any shots of the roof and pillar repair(before and after)
Did you fab the pieces or cut good pieces from a donar truck?
I'm in the same boat with my '61 and have considered a few different paths to take,from individual donar pieces to lopping off the whole roof !?
I have a thread in P & B("Roof swap") but no replies (pics are there too)
Hope I'm not jackin' your thread ,but I really need an opinion about this.
Thanks,Trent
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-07-2008, 07:37 AM   #14
62 short step
60-62 trucks the radiator bolts to the radiator support, but they do have a crossmember up front to keep the frame together. Since you don't have one, you can get the crossmember from a 63-66 truck and bolt it in. Sorry I don't have any pics, someone else will have some though.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
Old 07-07-2008, 11:36 AM   #15
joe231
joe231's Avatar
looking very nice!!!
CHEVY ONLY
Old 07-07-2008, 10:11 PM   #16
Captainfab
60-66 Nut
Looking real nice
PM sent....
Old 07-07-2008, 11:36 PM   #17
protrash64
Resistance is Futile
protrash64's Avatar
I dont know if this will help or not, but on my 64 I remove the single ms/cylinder and bolted a 'vette ms/cylinder in its place w/ no problem. Both systems were manual; re-ran ALL the lines...
Your frame is looking very nice, clean parts are fun!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-08-2008, 02:36 AM   #18
83burban
63sbssbbw: This actually isn't the original cab. I got this one off of another board member about a month ago...thanks poorboy (Jason)...and was very surprised at how good of shape it was in. I still have the other cab if anyone needs a 62 cab in LA (free if you pick it up). I am not a fan of cutting up a good cab to fix a bad one, however, piecing together a good one from two bad is fine by me. I would look for another cab and just get the pieces you need. I imagine that good stuff would be hard to find that far north, so if no one takes this cab then maybe I can cut off some of the smaller stuff and mail it to you. Send me a PM if your interested.
Captainfab: Thanks for the PM, I sent you one back.
Protrash: I am using an original power brake booster off of a 64, and I got a master/prop from CPP. I have changed plans a little bit as a result of my budget, so I am only running disc up front.
Thanks for the replies everyone.
Old 07-08-2008, 02:52 AM   #19
83burban
A couple of you have asked for details about the powder coating and blasting, so I figured I would just post it up to all those who are curious. The shop is just outside of Los Angeles. The bill totalled 1025:
575 for frame, cross-members, control arms, trailing arms, axle housing
450 for blasting and primering the cab
Here is the information for the shop:
Lee
Blasting Specialties and Powder-Coating
1-323-721-5020
http://www.blastingspecialtiesandpow...g.com/home.htm
Great guy to work with.
Old 07-08-2008, 07:07 AM   #20
63sbssbbw
UCA63
63sbssbbw's Avatar
Thanks 62
I'm not a fan of cutting up good stuff either
The '63s floors and rockers are absolutely shot
but for $250 for the whole truck it had everything I needed and not much that I didn't I wasn't gonna say no.
Aside from the ws and dogleg issue all my '61 needs is a pass side floor pan and front cab supports.
Looks like a great deal you got on pc and primer, it's looking awesome!
I'll try to get some pics of the x-member your looking for.
It's been rainy here lately though
Thanks again,T
member#7816
'61 GMC in progress
