05-08-2008, 03:54 AM | #1 |
converting form 3/4 to 1/2 ton front suspenion q's??
i'm looking to convert my 3/4 ton 68 chevy 2wd to 1/2 ton suspension. what's my best bet for the front? all of the control arms are pretty scaley so I plan on buying new ones. will the 1/2tons bolt onto the frame with no modification? i would think if they did that would be the easiest way.
thanks, Dave |
05-09-2008, 04:56 AM | #2 |
Re: converting form 3/4 to 1/2 ton front suspenion q's??
bumpity
05-11-2008, 06:59 PM | #3 |
anybody?
05-11-2008, 07:59 PM | #4 |
PROJECT 7DEUCE
If you can fund the whole front crossmember from a newer truck with disk brakes you can bolt it right up to 72 I believe. Anything later is pretty much a bolt in ,but you do have to drill some holes but im not sure which ones they would be..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-12-2008, 04:00 PM | #5 | |
I did the 3/4 to 1/2 ton swap on my 68 but I wanted to keep it looking like a 68 with the 6 lug rallys. I had collected various parts here and there including the rear trailing arm cross member, arms, etc. I love the coil sprung suspension... good luck
78 C10 LWB Super Cheyenne |
