Old 05-08-2008, 05:33 AM   #1
og350
og350's Avatar
i need muffler help!!
ok i need help picking out mufflers for my truck. i know its not a big deal but its all about the sound!! i have a 350 sbc with a th400 that i am putting a set of long tube flowtech headers on and am going to run true duals back. i want a good sound but it will be a daily driver so i dont want loud! i am thinking of dumping them in front of the rear tires but if you guys think that will be to loud then i will go out the back. thanks for the help!
oh one more questing should i run an h pipe? do they really help with power?
og350 is offline   Reply With Quote
Old 05-08-2008, 11:50 PM   #2
Wrenchbender Ret
Re: i need muffler help!!
Use real long glasspacks with pipes no larger then 2 1/4 in. I don't like H or X pipes. They don't sound as good. Go out behind the rear wheels or under the rear bumper.
Wrenchbender Ret is offline   Reply With Quote
Old 05-09-2008, 01:09 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
Some board member, (I don't remember who), had these: http://store.summitracing.com/egnsea...=KeywordSearch
He had a link to a video of his truck running, sounded like Flowmasters...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-09-2008, 01:13 AM   #4
bigsnookmaster
bigsnookmaster's Avatar
I run Dynomax Race Magnums with an X-pipe dumped behind the rear axle.I have 3" mandrel bent tubing.It's got a nice sound and the race magnums seem to make good power.I've got a 406 roller motor thats pretty healthy also.This exhaust in 2.5" or 2.25" would work well.It's really not too loud,unless you stand on it.Good kuck
bigsnookmaster is offline   Reply With Quote
Old 05-09-2008, 01:22 AM   #5
samwise68
FarmBoy.
samwise68's Avatar
I'm going to suggest long glasspacks as well.
I have 26" cherrybombs, with 2" in/out on my truck, with a 307. It goes headers, glasspacks, then pipes out in front of the rear tire.
I like the sound, it's not *real* loud, and talks when you get on it. I've been told it's "distinctive", so apparently people don't dig glasspacks much anymore. -shrug-. Just my 2 cents.
I have some sound clips if you'd like an example, just lemme know.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 05-09-2008, 01:22 AM   #6
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
X-Pipe + Dual Flowmaster super 44's = Nicest sound i have ever heard.
just my 2 cents
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 05-09-2008, 04:03 AM   #7
og350
og350's Avatar
thanks for all the info keep it coming! if anyone has sounds clips let me know that would be great!
Old 05-09-2008, 04:21 AM   #8
samwise68
FarmBoy.
samwise68's Avatar
As requested.
at idle.
in the cab.
drive by.
and of course, screwing around, and smokin' the tires.
hope that helps some.
-Sam.
Old 05-09-2008, 04:28 AM   #9
rick0312
rick0312's Avatar
check out the dynomax site. you can change mufflers with their online tool and hear the different sound.
http://www.dynomax.com/sounds/flash/sounds.html
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 05-09-2008, 04:50 AM   #10
Riveted1
Tasty Cakes!
Riveted1's Avatar
Sorry I don't have any sound clips of mine (it's not running atm), but I have 40 series Flows dumped right in front of the rear axle. IMO, if you're gonna do a lot of driving in it, don't use the 40's or dump it. I think it sounds awesome, but I get lots of in-cab resonance. Gotta raise your voice to talk, and forget about using your cell phone! (probably shouldn't do that anyway If I had dynomat or similar, it probably wouldn't be as bad. When I finally get her back on the road, I'm probably at least going to reroute to in front of the back tires and out to the sides.... Just my .02!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-09-2008, 04:59 AM   #11
lilred67
lilred67's Avatar
i'm running dynomax ultra flo's.ram horn's, 2 1/4" pipe,h-pipe,dumped at rear bumper. nice sound running through the gears and when getting on it pretty good. just a noticble rumble at cruising speed. removing the h-pipe will make it louder.i just wanted something different, everbody has flowmasters.
lilred67 is offline   Reply With Quote
Old 05-09-2008, 06:42 AM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have the same dilemma... I have had 36" glasspack blanks for many years and they need replacing. I liked them a lot, they sounded great and not noisy at all -- just a nice mellow V8 burble. But they were Walkers, and Walker is out of business, so I don't know what to get. Virtually all my driving is short trips and the exhaust never gets hot enough, so moisture is a big problem for me. For that reason, mine dump just behind the mufflers, ahead of the rear axle.
Edit: Ack!! Just Googled Walker, they are alive & well.. so my old blanks were another brand and I cannot recall what. Oh well...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-09-2008, 06:47 AM   #13
lukecp
Formerly yellow72custom
lukecp's Avatar
I have dumped 40 series Flowmasters on my truck and it sounds awesome, but I too agree on not running them that way if you drive it a lot. It would get annoying quick, but it was great when I was in high school. I don't like glasspacks that much as they are kind of cackly, especially with shorter ones, but long glasspacks sound quite a bit mellower.
Sound clip of my truck: 350 with headers and 2.5" pipe, and the mufflers just end, no turndowns or anything...underneath the bed
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 05-09-2008, 06:57 AM   #14
Premium72
Premium72's Avatar
350 mild cam flow tech headers flowmaster 2 chambers ran out the back 2.5 in pipe all the way.. nuthn really at all in the cab less you stomp it!!
Premium72 is offline   Reply With Quote
Old 05-09-2008, 07:06 AM   #15
67heavychevy
hello i have an x pipe on my truck and flowmaster 40's. they come out in front of rear wheels it sounds good but kinda noisy in cab . putting it out the back should be great sound not 2 loud and i believe with the x pipe it makes it a little less noisy.
67heavychevy is offline   Reply With Quote
Old 05-09-2008, 07:10 AM   #16
whitesswj
Embrace the Redneck
whitesswj's Avatar
I've got a 350 w/ a np a833 tranny.
Using Flowmaster 40's, headers, 2.25" pipes out infront of the tires.
It's my daily driver sounds good when i need it to and quiet when i travel.
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 05-09-2008, 03:37 PM   #17
68Stepbed
68Stepbed's Avatar
I have 2.5" pipes with Flowmaster Super 40's. I love the way mine sounds, but if I were driving it everyday, it would get on my nerves. I suggest some Flowmaster 50 series Delta Flows. I had these on my 86. They sound great. Nice and mellow at idle and cruise, but still make enough noise when you get on it. Here's some videos.
My 68 with the Super 40's.
My brother's truck with original 40's. Too loud IMO.
My dad's MC SS with Delta Flow 40's and his ElCamino with Delta Flow 40's.
Here's a link to my 86 with the 50 series Flows.
http://videos.streetfire.net/video/H...Flow_60865.htm
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-09-2008, 05:41 PM   #18
manimal
manimal's Avatar
I myself(no offense to ANYONE!) cannot stand the soound of glasspacks. They remind me of a clapped-out old ford. But to each his own.
I like the Flowmaster 50's,super 40's,and the Dynomax race Magnums. Hooker AeroChambers sound very nice also. Good Luck.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-09-2008, 07:04 PM   #19
orange72c10
I have long tube headers that flow back to the x pipe which is right under the cab and it flows back to flowmaster series 40's which are located under the bed and the pipes dump behind the rear wheel, I use mine a daily driver, well on the nice days and I love it. The cab noise is not bad at all and it does sound good as youd rive it down the road. I would recomend that set up, it will work nice for you.
orange72c10 is offline   Reply With Quote
Old 05-09-2008, 07:19 PM   #20
dznucks
dznucks's Avatar
does anybody have any opinions of edelbrock mufflers?
I have glasspacks now that need replacing and i want something quieter. Flowmasters and Dynomax are too loud...or i've grown too old.
dznucks is offline   Reply With Quote
Old 05-09-2008, 07:30 PM   #21
70rs/ss
70rs/ss's Avatar
Put the muffler as far back as possible then the drone or resonance isn't bad. I only run flows, I have an old set (over 20 years now!) on my 70 camaro and I have a couple of sets on the BBC 454 SS truck and another new set for my 2wd Blazer. Again the 40's or 44's are loud, but the 50's and up are mellower. I HATE GLASSPACKS!! The rednecks around here think that crackle snap pop is so coll, but well you know! Borla, Flows, dynomax, etc are better than a glass pack. BTW X or H pipe is more about equalling out the exhaust pulses from DS and PS banks on the motor which can create a bit of power as well, X pipe really helps scavenging, and all the way out back otherwise anything will be loud. I ran 3" 2 chambers off of a BBC that ended before the rear, it was crazy!! I loved it, but some thought it was loud.
70rs/ss is offline   Reply With Quote
Old 05-09-2008, 09:13 PM   #22
pmpski_1
pmpski_1's Avatar
I was going to ask this same question. I have an Edelbrock muffler on my motorcycle and I like the sound, but it's an apples to broccoli comparison between a bike and a truck...
(If you're scratching your head about the Edelbrock on a bike...It is a custom exhaust made by Latus HD for Buell. From what I know, they took an Edelbrock muffler and modified it to fit on a Buell XB. Loud and torquey.)
pmpski_1 is offline   Reply With Quote
Old 05-09-2008, 09:16 PM   #23
samwise68
FarmBoy.
samwise68's Avatar
I don't have any experience with the, but I've heard really good things about Thursh turbo and welded mufflers (not to mention their glass and steel packs).
Jakes68GMC has Thursh turbo's on his truck, if I remember right. Maybe he'll chime in, but I know he's gotten some compliments on the sound of his truck.
snap, crackle, pop.
-Sam.
Old 05-09-2008, 09:40 PM   #24
Riveted1
Tasty Cakes!
Riveted1's Avatar
That's the ticket right there! Sounds good! I like the chirp you get goin into second too
Old 05-10-2008, 12:16 AM   #25
Ol'Rover
Ol'Rover's Avatar
lol good i wasnt the only one that heard the chirp goin into 2nd! awsome truck, awsome sound! Im probably going to go with a flow 40 single in dual out. or a 44.
