Old 05-08-2008, 07:10 AM   #1
1980GMC
1980GMC's Avatar
Big Block Casting #?
I pulled a 454 out of a 78 Royal Sierra to transplant into my truck, but when I went to find the casting # it only had this: 861959
Looked on mortec BBC castings page and didnt find anything. Just trying to find out the info on the block. If it helps I can get the VIN number tomorrow.
Any info is appreciated.
Wes
1980 GMC Sierra SCSB-2WD
1986 Chevrolet C10 SCSB-2WD
1980GMC is offline   Reply With Quote
Old 05-08-2008, 03:32 PM   #2
manimal
manimal's Avatar
Re: Big Block Casting #?
I pulled the same out of my '79 dually. The book said '73 Chevelle & fullsize,and '73-'79 light duty truck.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-08-2008, 04:17 PM   #3
1980GMC
1980GMC's Avatar
Thank you very much Manimal
Wes
Old 05-09-2008, 04:32 AM   #4
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
I'm finishing mine now... should be starting it this week... waiting for a decent day to come up first. 361959 is a "pass"-enger car block. It was put in trucks too though. Mine had 781 heads on it which are ovals and great heads. Some massaging, bigger valves, etc and they'll be great flowing heads.
Here's a thread I started a while back: http://67-72chevytrucks.com/vboard/s...d.php?t=279281
BEFORE
AFTER - ALMOST READY TO START
Kenny
87Lowrider is offline   Reply With Quote
Old 05-09-2008, 07:48 PM   #5
1980GMC
1980GMC's Avatar
I think I might have made a mistake and read the numbers wrong. I probably mistook the 3 for an 8, because there was alot of grime to get through. Ill check when I get home. thanks for the help guys. and great looking motor 87Lowrider
Wes
Old 05-10-2008, 01:36 AM   #6
87Lowrider
87Lowrider's Avatar
probably so... I never found any casting numbers starting with 861... I had to wirewheel the casting number to see it clearly. Initially, I thought it was 361858, but for my 42nd birthday, I got a pair of reading glasses
Old 07-29-2008, 03:08 PM   #7
watahyahknow
watahyahknow's Avatar
nice one , was the truck setup for the big block originally ?
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-29-2008, 07:54 PM   #8
87Lowrider
87Lowrider's Avatar
If you're asking me, no, it wasn't. But, I didn't have to change anything to get the BBC put into it. Motor mounts from the '76 (which I actually replaced with new) were identical and fit perfectly over the mounts on the frame.
Of course, being a '87, I had to eliminate all of the TBI harness connections that I didn't need anymore. I just tucked them away since I may upgrade it to TBI in the future, I'm not sure yet.
Since it is soooooo low to the ground, I had to replace the front springs which had been cut by 2 loops. I put different springs in that had only 1 loop cut out and it still sits about 1 1/2" higher in the front than it did with the 350 in it. But, it doesn't drag over speed bumps any longer either.
Man, what a difference in torque and power!
Here's an updated pic with some minor upgrades to the jewel:
Kenny
Old 07-29-2008, 11:21 PM   #9
watahyahknow
i have a partstruck ith a 454 in it doesnt run yet (carb is giving me probs might be the 5 year old fuel thats still in there )
i was planning on putting that one into a truck now fitted with a 350 thats why i asked , i'm too lazy to bold the crossmember out from under the donor , i prolly will switch the radiator though
