Old 11-04-2002, 05:45 PM   #1
fastbagged68
fastbagged68's Avatar
Do they make a plug to go into the speedo gaer in the tran.
My tranny is leaking from the speedo gear cable and need to fix it. Do they make a plug to put in it. So I would not be running a speedo.
fastbagged68 is offline   Reply With Quote
Old 11-04-2002, 06:18 PM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Shouldn't cost you much to get a new gear and "bullet" at a transmission supply shop. My gear had a groove in the shaft and the o-ring in the "bullet" was shot, so I bought a new set. Transtar is the name of the company in Denver, maybe they have a store in CA?
Here: www.transtarindustries.com
If you still want to go with the plug, try some speed shops where people wouldn't want a speedo for a race car.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 11-04-2002, 08:48 PM   #3
mikep
Used to have a truck
mikep's Avatar
If you want gibve me the dimensions and I'll machine you one out of bar stock. You'd be better off fixing it though.
No truck :-(
mikep is offline   Reply With Quote
