Old 05-08-2008, 06:04 PM   #1
JCampbell
Gas stations are making me angry.
...and it's not just because of the price of fuel.
Anybody have issues with certain gas station nozzles not being compatible with your 73-80 truck?
Seems like about 45% of the time when I go to fill up, I have to dick around with the nozzle to get it to work. Sometimes I get it right on, sometimes it kinda works but spills about $10 worth of gas down the side of my truck and onto the ground, and the other times it just flat out won't pump. It will run for a few seconds, then it shuts off. Even if I stand there and hold it manually, or flip the nozzle upside-down it still won't pump.
It's pissing me off.
Seems like the only stations that don't give me any issues are the commercial card lock stations.
I'm thinking about doing something just like this-
I think by eliminating all the bends and other restrictions of the stock fill system and basically making it a straight shot, I will eliminate most, if not all, of my problems.
Think beer bong for your fuel tank.
Any thoughts?
JCampbell is offline   Reply With Quote
Old 05-08-2008, 06:19 PM   #2
SBellew
Re: Gas stations are making me angry.
Maybe you could fashion up some type of neck extension to put in there when you go to fill up and help with the problem. Just put a o-ring at the bottom to prevent overflow.
~Scot
'77 C10
My build thread (Its a slow one)
SBellew is offline   Reply With Quote
Old 05-08-2008, 06:34 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
God bless California and their emission rules---they can screw up just about EVERYTHING. We don't have that problem in Kansas and filling the truck is easy here.
piecesparts is offline   Reply With Quote
Old 05-08-2008, 07:40 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Thats my only gripe about 73 to 78.5 - The fuel caps. It's very tough to avoid spilling some out. Sometimes it'll stop just fine and none will spill. Sometimes I can fill it as slow as I possibly can, and it'll still blast out like I was pumping full blast. It almost seems like an air pocket forms and when you get to a certain point. It tries to escape but at the same time it pushes a bunch of fuel out too.
Pyrotechnic is offline   Reply With Quote
Old 05-08-2008, 07:44 PM   #5
JCampbell
You said it. 99.9% of the problem is directly related to the Golden State's mandated vapor recovery system.
Old 05-08-2008, 08:38 PM   #6
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
I've been having the same damn problem... Exact same thing, and its wierd cause half of the time its fine, but others... its hell...
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 05-08-2008, 08:40 PM   #7
BowTieOgre
Most of the places I fuel up the '80 give me issues. I have to pull the nozzle about half way out and angle it towards the front of the truck to get it to pump without shutting off after 2 seconds or spraying gas at me. That combined with the fact that my truck is lowered make it doubly awkward to top off the tank.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 05-08-2008, 09:54 PM   #8
Rooster's82
Rooster's82's Avatar
HA! I knew i wasn't going crazy! This is my first truck with 2 tanks...i would go to gas station thinking yup i'm on the left tank, look at my hands to see which one makes an "L" pull up to the pump....start pumping only to shut of 2 seconds later. So i go in the truck look at the switch, look at my hands....yup thats the right tank why aren't i pumping? then i start thinking maybe the switch is messed up...so i turn the truck around try to fill the right tank...gas pukes everywhere....yup that one is full. go back to the left tank...damn pump turns off after 2 sec again. At this point i'm freaking pissed and a little embarrassed seeing how the 19 year old girl filling up her dads Hummer has already pumped $220 worth of gas. So i pay the $15 dollar bill and hit the road.
Now i only fill up at the Racetrack gas station by my house...never had a problem there.
JG
If you can't find it at the junk yard you don't need it.
Rooster's82 is offline   Reply With Quote
Old 05-08-2008, 10:26 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
Live in Cent Cal and have no problems here filling my 83, and i've been to a few different stations looking for the cheapest gas when I fill up I push the nozzle all the way in and then let it hang by itself with that clip on that keeps the flow going without having to hold it
Malo83 is offline   Reply With Quote
Old 05-08-2008, 10:38 PM   #10
JCampbell
LMAO!!! I do the exact same thing! I feel retarded sometimes, but hey, I get confused easily.
...At this point i'm freaking pissed and a little embarrassed seeing how the 19 year old girl filling up her dads Hummer has already pumped $220 worth of gas. So i pay the $15 dollar bill and hit the road.
LMAO x's 2!
I don't know how many times I've boned out of the gas station with like, $2.50 worth of gas.
Okay well, I feel a little bit better since I know I'm not the only one.
Old 05-08-2008, 10:39 PM   #11
screwballl
Tonawanda 454
screwballl's Avatar
I had a similar issue with my 76 (before I upgraded to my 91)... I found that at least here in FL, if you pull it out about 1-2" it fills perfectly and stops properly.
I do not have this issue with my 91 burb...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 05-08-2008, 10:40 PM   #12
JCampbell
Originally Posted by Malo83 View Post
Live in Cent Cal and have no problems here filling my 83...
Doesn't happen on my '88 either. It's a 73-80 issue. It has to do with the angle of the filler being flush with the side of the bed. It just wreaks all kinds of havok on my mental health.
Old 05-08-2008, 10:41 PM   #13
JCampbell
Originally Posted by BowTieOgre View Post
...That combined with the fact that my truck is lowered make it doubly awkward to top off the tank.
X's 2
Old 05-08-2008, 11:33 PM   #14
Malo83
Cruzzzn' Vet
Malo83's Avatar
Ahhhhh well that answers that.
Old 05-09-2008, 12:21 AM   #15
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
The only issue I have is since I lowered my ride and I'm 6'7" I gotta bend over a bit more. Other then that. Every nozzle here in J-Ville fits.
But I do like that idea of relocating the filler into the bed. Have a smooth shaved bed. Keep us posted. if ya try it.
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 05-09-2008, 08:55 AM   #16
EN*PN78
EN*PN78's Avatar
Same problem here in Oregon. Only we get to pay people to pump our gas. I use two different stations only and the boys know me and let me do it myself because of this problem.
I saw a 73 show truck, way prettier then mine. I asked the guy about this because he had about a 10,000 dollar paint job and he said he got a hose with a about a 15/16 to 1" inside diameter about 1 foot long to slide over the pump nozzle and stick the darn thing down the tank for the most part. Said work great.
I never bothered to try this out. I guess its just part of the truck for me. At least the gas stain on my paint is.
EN*PN78 is offline   Reply With Quote
Old 05-09-2008, 03:38 PM   #17
Rooster's82
LMAO x's 2!
Glad I'm not the only one.
JG
Old 05-09-2008, 06:38 PM   #18
f.monroe
f.monroe's Avatar
Try this . I work on gas pumps and point of sale systems for a living so I am at stations all day long . I see diesel truck owners trying to fill up and they have problems since Diesel foams so bad . Especially on older Fords since the fill tube runs level until it gets inside the frame of the truck . The cure seems to be using a 4x6 piece of lumber cut at an angle so you drive up on it . They keep it in the truck and drive the rear tire up on it to give the truck a little lean away from the filler neck . They always take fuel better this way . It might be worth a try . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 05-09-2008, 07:42 PM   #19
JCampbell
I think I'm gonna try the hose trick before I start to redesign my fill system.
I'll report back with the results.
Old 05-10-2008, 02:48 AM   #20
Kixwy2
Kixwy2's Avatar
My 74 has this problem too - there's only one gas station in town that will pump slowly enough and have the vapor lock soft enough for me to pull back to pump shorter than 20 minutes... Argh.
Anyway, I have a 3 inch PVC round that I got at OSH which I use as a spacer for the vapor lock - it's about 1.5 inches thick. Works great. Of course, it kinda ghetto. How I roll.
1974 GMC C-10; my new addiction
1998 4 Runner; daily driver
Kixwy2 is offline   Reply With Quote
Old 05-10-2008, 04:56 AM   #21
f.monroe
f.monroe's Avatar
If you are running gas through the 3 in PVC be careful . All rubber hoses at gas stations are static bonded hoses . They have an internal static strip that runs the length of the hose . You can measure resistance from one end to the other and there is continuity. Without it the hose can/will build up a static charge and it will go to ground when it gets a chance . Many fires have been started this way . PVC isn bonded and might give you a surprise one day . Just something to consider . Frank
Old 05-10-2008, 05:15 AM   #22
62 C60
62 C60's Avatar
try not to jam the nozzle down in the neck. when you do this it seals it off and the vapors cant escape so the pressure kicks off the pump.
-Jake
1962 C60 261 I6 5+2spd I like to be different
Interior- Puke green dash, brown vinyl seat from an 87.
Exterior- Rust
1993 Full Size Blazer 4x4 Stock for now.
If you have a truck everyone is your friend. When they need to move.
62 C60 is offline   Reply With Quote
