Old 05-08-2008, 11:08 PM   #1
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
Carrier bearing update
I had the carrier bearing replaced for the second time in ten months, i also had the drive shaft balanced again. I was told that my drive shaft was out of phase, whatever that means. The guy that did the work said,if it happens again,he would put in a one piece drive shaft and be done with it. I don't know how long it will last,but it does seem much smoother than before. I just wanted to thank all of you for your help.thanks
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 05-08-2008, 11:13 PM   #2
brian10048
brian10048's Avatar
Re: Carrier bearing update
I just broke my carrier bearing about a week ago after only driving my truck for a bout two months, and just went ahead with a one piece shaft. It cost me a little, but I am pretty sure i won;t have any worries with this one. Glad to hear you got yours going better though. Good luck.
Stock 454 & 700R4 for sale
Parts for Sale:
Roll Pan
BBC Exhaust Manifolds
Stock Spindles & Springs
and More
http://67-72chevytrucks.com/vboard/s...d.php?t=287817
http://67-72chevytrucks.com/vboard/s...d.php?t=291000
brian10048 is offline   Reply With Quote
Old 05-08-2008, 11:27 PM   #3
Brad
Out of the carpool lane.
Brad's Avatar
I've advocated for years that the carrier bearing is a PITA and although it can be set up properly and give another 40 years of reliable use, the time and trouble in doing so -you'd be miles ahead just doing a 1-piece driveshaft. Most econo c.b.'s out there require welding them up completely since the spot welds don't hold and even then it's a gamble.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
