Old 03-23-2002, 11:21 PM   #1
Alex Hayley
Question question about play in front end
When I grab the front wheel at 12 and 6 o'clock a wiggle the wheel I have some play...just enough to feel a knock. At 3 and 9 o'clock I have no play at all. What does this indicate? Ball joints or wheel bearing? Thanks...
Alex Hayley is offline   Reply With Quote
Old 03-23-2002, 11:30 PM   #2
Brad69
Crash Test Dummy
Post
I would think that wheel bearing play could be felt no matter where your hands are (actually if you can feel it that is very bad). So it could be either ball joints, or the A-Arm bushings. Lots of folks don't lube the A-Arm bushings often enough.
The more hair i lose, the more head i get.
Build Sheet:
1969 C-10 short fleet
Constructed by taking a 3/4 ton rolling frame from one truck, adding a rust free AC Cab from another, then a bed from another, 1/2 ton front suspension & brakes from another,add in one Goodwrench crate 350, painted DuPont Arctic White,and driven daily.
Brad69 is offline   Reply With Quote
