what all do i need
im getting ready to redo my front end.. what all do i need..
i made a list upper and lower ball joints inner and outter tie rods ends tie rod sleeves upper and lower control arm shafts pitman arm idler arm did i leave anything out thanks |
Re: what all do i need
Nope sounds about right to me
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
Restoration Virgin!
if you need upper and lower a-arm shafts...checkout my parts for sale....
http://67-72chevytrucks.com/vboard/s...d.php?t=289716
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
![]() Join Date: Apr 2008
Grease!
Life, Be In It.....
![]() Join Date: Oct 2003
If you want a quality rebuilt kit, rather then a cheap one, I would go with the kit that Early Classic sells. They use all Moog parts.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
I am a Referee of life.
You left out "PAINT". If you are going to do all of that you do want to paint everything.Also shims.You will not want to put the old dirty ones back in there after getting it clean and looking good.
I will warn you to ready for a surprise.I was done with the pass side and started tearing into the drivers side.That's when I found out the drivers spring was 3 pieces.I had to take the pass side apart again since I did not want to replace just one spring.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
