05-09-2008, 03:08 AM | #1 |
6 lug trailer ????
Did anyone here know of a 6 -lug trailer that takes a 4x4 ralley rim offset?
Homemade or just a e-gay guy messing with me?? |
05-09-2008, 03:12 AM | #2 |
Re: 6 lug trailer ????
Most trailers are built with f*#d hubs. Chevy 6 lugs will not fit because F*#d wheels have a larger hole in the middle. But you can run the F*#d 6 hole rim on a chevy.
05-09-2008, 03:26 AM | #3 |
Thanks Joeys toy, very cool of you to reply. I have a factory 5 hole ford wheel on mine. Looks cool with the ralley fat 3 inch rings, fit right on the 15 inch wheels.
05-09-2008, 03:58 AM | #4 |
I have a radical idea!
I have a Hardeebuilt car trailer and they actually have 5 on a 4 3/4 Chevy car or S-10 pattern wheels on it, so not all have the F*rd hubs. I've never seen a 6 lug trailer, but I have seen a lot of 8 lug trailers though they usually HD unit.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
05-09-2008, 04:21 AM | #5 | |
Bloo
they do make chevy hubbed trailer axles.. our cattle trailer's original axles had stock 15x6 chevy wheels on it. it now has new axles, which had the 6x5.5 lug pattern, but the hub center was bigger. we just cut off a lip on the wheels, but the trailer place said it was a special trailer sized hub
heres the trailer: the front wheel is a modified chevy wheel, the rear is an actual trailer wheel
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
05-09-2008, 05:08 AM | #6 |
the number of lugs on a trailer axle depend on the gross wieght of the axle.3500#=5 lug,5600#=6lug,7000# and up =8 lug.the older trailers had many bolt patterns but the more modern trailers with dexter axles i have seen,have a gm bolt pattern.
05-09-2008, 06:46 PM | #7 |
Living In The Past
I have built a number of traillers over the years. When It comes time to order the axles, I would specify what ever bolt pattern the customer wanted. and length of axle for wheel offset.
