65 - Chevy C10
Summit Headers
I think I asked this question before... But has anyone tried the summit brand headers? Im looking to pick some up real soon but dont know which ones to get. I have a 65 with a 350 sb. Im looking forward to headers with no clearance issues if anyone can suggest some! Thanks. Oh... and did I mention inexpensive???
#2 | |
Council of the Elders
Re: Summit Headers
There is a header thread down below with some specific recommendations, including pics. I highly recommend the Hedmans. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=286578 Don
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 05-09-2008 at 04:15 AM. Reason: add linky |
65 - Chevy C10
Re: Summit Headers
Thanks Don! From a budget standpoint, I am interested in these particular headers:
Summit Headers SUM-G9006 Anyone use them? |
#4 | |
Re: Summit Headers
#5 | |
Re: Summit Headers
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
65 - Chevy C10
Re: Summit Headers
Yes Don! Im wondering the same thing! I have an automatic and now Im looking at these flowtechs that i can pick up locally at kragen today. They are only $99 after $5 off coupon. They also state the 66 thing.
Resistance is Futile
Re: Summit Headers
Ihave posted this numerous times in different threads.....I used a shorty header for 88+ chevy pick -up w/ small block. Part # was sometning like 9016.
I had to weld up the o2 sensor hole but fit no problem......Im low so I couldnt go w/ the long tube. I think Dinos63 uses shorty's for early 90's Camaro and Firebirds w/ the same results.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#8 | |
Re: Summit Headers
The 66 thing has always puzzled me... maybe someone else knows the story of why a 66 is different than other 60s in terms of its header requirements. Whatever you buy, make sure there is a good stout mounting flange... esp. for the full length headers. Some newer models have also gone to a ball and socket type collector outlet, which means you don't need a gasket! Also please post your installation experience on the header thread! PT64's point is well taken about numerous postings... but IMO a clearly labeled thread with proven part numbers and pics would really be useful to members. ![]()
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 05-10-2008 at 04:37 PM. |
65 - Chevy C10
Re: Summit Headers
Hmmm... well this is my first header experience, so I am not keen as to what is a good mounting flange and what isnt. I think it was good but I suppose only time will tell.
Most threads are not specific enough. If you noticed I asked about the summit brand headers. Although now I will be talking about my experience with the Flowtechs. Oh well! Flowtech 11500FLT is the model I purchased from Kragen. So far I only had time to get the driver side in. The only clearance problems were undoing a grounding wire strap and the oil filter. Luckily I didnt loose too much of that precious oil. I also had to remove all the spark plugs to safely get them in without damaging anything. I was able to leave the temp sensor in. I will continue info with my passenger side install today! |
Re: Summit Headers
hurry up already! guh...slow poke! hehehe, nah Im stoked for you...now we just gotta finally get both our rides running at the same time! hehehe
#11 | |
Re: Summit Headers
The issues you describe with plugs oil filter etc. are just normal installation notes, not real problems with the functioning of the header. On the passenger side you will almost surely have to remove the starter (and plugs) to get the headers installed. This would be the case with almost any full-length header. Two main functional problem areas tend to come up with full-length headers: 1. flimsy thin mounting flanges that prevent the header from sealing well with the exhaust ports (note that these bolts support the front of your exhaust system) and 2. getting the collectors to seal well with the exhaust pipes... where gaskets tend to fail pretty often and allow leaks. You may have to experiment with gaskets to get ones that give you the best service life. Another issue that sometimes comes up is just the bends at the top of the headers allowing enough room to get a header bolt in and tightened down well. It sounds like your installation so far is routine, but like you said it may take a while to see if problems develop and persist in the two areas I mentioned. Do the headers burn out gaskets and stay sealed over time is what it amounts to. I agree that many posts to threads aren't specific enough... mostly because people give incomplete info : "a buddy of mine uses the Schmidlaps and likes them...." But before long you will have valuable information on the specific Flowtech header you bought and should be able to report whether or not it installs and functions reliably in our trucks. And is it known to fit only automatic tranny or both auto and manual... stuff like that. People seem to value specific information like that. I do anyway. Heck I'm also just curious as to how it comes out for you AND I love pictures. ![]()
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 05-11-2008 at 04:28 AM. |
65 - Chevy C10
Re: Summit Headers
I do realize that removing plugs is standard, I just mentioned it cuz it is what I did. Anyhow, got the passenger side in just now and it went in pretty easy. I just had to re-route some starter wiring but again... no big deal and to be expected. Same with the plugs on passenger side. Fortunately I did not have to drop the starter to get it in! As for the sound... It was pretty sweet! Its a MONSTER right now
![]() Here is a link to the audio of my startup. Its headers only and I think the sound is distorted from the cheap mic in my digital camera. |
#13 |
'65 GMC Project
Re: Summit Headers
That was a cool video! sounded sweet! I'm diggin the bullet shifter
Beauty is in the eye of the beer holder 1965 GMC project 1999 GMC Safari (daily driver) 2005 Scion XB (Wifey's car) Last edited by magooster; 05-11-2008 at 10:19 AM. |
#14 |
Re: Summit Headers
Totally *****in' sal44..........dig the vid!!!!!!!!!!!
#15 |
65 - Chevy C10
Re: Summit Headers
haha... thanks guys! Im headin down in a bit to finish the piping. Gonna add some flowmasters 40's!
#16 |
Re: Summit Headers
yeeeeew! thats awesome Vic, fawk cant wait to get my ride back today (hopefully)....ill try and make a clip of the lakes for you
#17 |
Hey Watch this...
![]() Join Date: Sep 2007
Re: Summit Headers
I put those on my '64. They fit fine, but I had to temporarily remove the oil filter and starter to squeeze them in. That and a Z-bar modification.
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
#18 |
Re: Summit Headers
Vic:
Well done! And beware of open header induced euphoria! Post a pic of the headers when you can. The real long term test will be whether or not the headers develop leaks at the mounting flanges or the collector gaskets.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 05-21-2008 at 04:09 AM. Reason: clarification |
#19 | |
Justified!
Re: Summit Headers
Ordered last Wed, they showed up on Thursday! ![]() I installed them Friday nite. Very easy, and I have to say they sound AWESOME! of course I scraped paint off of them putting them in, but for only $ 88.00, you can't expect perfection!!! For what I am doing, and for the price, I am very satisfied with them! Now I just need mufflers! Chad
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() Last edited by 64GMCHorsepower; 05-20-2008 at 03:46 PM. |
#20 |
65 - Chevy C10
Re: Summit Headers
yeah... i scrapped paint also.
#21 | |
Re: Summit Headers
