Old 05-09-2008, 04:01 AM   #1
nac593
gas tank boil? filter? opinion
The truck has been sitting for 2 or 3 years. I just put a new engine in it. I put a filter before and after the fuel pump and ran 5 gallons thru it. Engine runs good.
The filter before the pump collected dirt. I want to take it off because its over the exhaust and I heard it could cause a vapor lock situation. I'm wondering if it collected all the dirt in the tank. Should I take the tank out and get it cleaned and boiled? Is the quadrejet filter enough?
nac593 is offline   Reply With Quote
Old 05-09-2008, 04:26 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: gas tank boil? filter? opinion
I would remove that inline filter that is before the pump, it can cause vapor lock, not so much from the exhaust heat, but from the reduced pressure it creates, which in turn, lowers the boiling point.
installing one on the pressure side of the fuel line (after the pump) is a great idea.
As for your tank, does it actually have crap in it?
Old 05-09-2008, 04:42 AM   #3
nac593
About 1/4 of the filter had dirt in it.
Old 05-09-2008, 04:47 AM   #4
nac593
Will the fuel pump be o.k. if I just run a filter after it? I was thinking it should be filtered before going thru the pump to prevent damage or failure.
Old 05-09-2008, 06:05 PM   #5
nac593
Anybody else have an opinion?
Old 05-09-2008, 11:39 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
"When in doubt,call out!"
That is a quote from an old Maintainence tech I worked with.
In your case
"When in doubt,boil it out!"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
