Old 05-09-2008, 04:30 PM   #1
nac593
Need to cover old stick shift hole.
I switched from a stick to automatic. Now I have a big hole in the floor. Is there a small replacement panel for this? What should I do?
nac593 is offline   Reply With Quote
Old 05-09-2008, 04:34 PM   #2
bedsled71
bedsled71's Avatar
Re: Need to cover old stick shift hole.
you could weld it up or cut out a piece of sheetmetal alittle bigger then the hole. then screw it in over it and silicone it
bedsled71 is offline   Reply With Quote
Old 05-09-2008, 05:01 PM   #3
Shane
Shane's Avatar
Weld it. Leave the silicone to the plumbers.
Shane is offline   Reply With Quote
Old 05-09-2008, 05:45 PM   #4
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Call a local body shop and see if they have an old hood laying around that you can cut up for patch panels.
I got one off a newer chevy truck, and its pretty thick metal. I've been making all my panels out of that. Plus the guy just gave it to me, he was happy to have it out of the way.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-09-2008, 07:20 PM   #5
If your truck is a high hump (the tranny hump bolts in) you could scan the parts board for a floor hump without holes. Other wise welding is you best option.
Palf70Step is online now   Reply With Quote
Old 05-09-2008, 07:33 PM   #6
nac593
It looks like it will take some patience trying to make a patch panel match without the proper tools!
Old 05-10-2008, 07:15 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Do you have carpet or a rubber mat that will be covering this area once you fix it?
If so, it doesn't have to be a concourse repair or even welded in. Just grab some cardboard and make a template that is about 1" bigger then this hole and got to a body shop and I bet you they would cut you out a piece from scrap. Drill a few holes around the overlap and screw or bolt it down and call it good. A little bead of silicone will seal it up just fine.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-10-2008, 07:20 PM   #8
michael bustamante
michael bustamante's Avatar
i cut a piece out of sheetmetal and screwed it in and beaded a non hardening silicone back in 2001, its still holding good to this day.
Now that I said that, the Dang panals gonna fall off when I drive home. jinx
1967custom
michael bustamante is offline   Reply With Quote
