Old 05-09-2008, 04:33 PM   #1
gn4u2c2
part number help tilt column 72
yes I used the search feature but no clear anwser
I work at GM dealer but parts guy is not able to locate these older parts without the #'s they no longer have the pre 82 microfilm or books.
I need the cancel cam for tilt
I need the upper steering column bearing, for tilt
I need the upper thrust washer(wedge washer) for tilt
I need new upper thrust washer/wedge nut
I understand the race is not avalible if anyone has found a suitable replacement please advise thanks
If you do not have a anwser please don't post trying to keep a clean neat to the point thread thanks.
gn4u2c2 is offline   Reply With Quote
Old 05-09-2008, 04:38 PM   #2
lowriden58
lowriden58's Avatar
Re: part number help tilt column 72
im no help but which dealer you work for? i work at McCullough AKA Koons Pontiac in marlow heights
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 05-09-2008, 04:54 PM   #3
gn4u2c2
Frankel GMC Owings Mills .
I belive I found the issue looking here http://www.americanclassic.com/asp/d...=1972&ytype=to
It looks like my tilt column has a non tilt bearing assembly in it as it does look like its been serviced but it is just to small of a bearing for the housing.
If I don't get a definate GM part number for the correct one I will just order it there and roll the dice.
If your up this way drive your truck I would like to see it
Old 05-09-2008, 05:00 PM   #4
lowriden58
lowriden58's Avatar
yeah we used to have the old books here somewhere with all the good stuff in them
im actually gonna be coming thru that way next wed.. trailering the beast to PA for a dyno tune
Old 05-09-2008, 05:45 PM   #5
gn4u2c2
where at in pa ?? I know almost every shop up this way.
Old 05-09-2008, 05:48 PM   #6
lowriden58
lowriden58's Avatar
SGS up in gettysburg. they used to be kauffmans.
Old 05-09-2008, 06:06 PM   #7
gn4u2c2
sweet I know right where that is , do you know about what time ?? Just courious I may swing by if you don't mind and see what it throws down if i can get 1/2 day off work.
Old 05-09-2008, 06:09 PM   #8
lowriden58
lowriden58's Avatar
we have appointments at 9am. not sure if my truck will go first or my buddies stang. mine is gonna take longer to tune then his
i was really hoping to have the NX kit installed before we went so i could throw the 200shot to her but funds are not allowing this month
Old 05-09-2008, 06:51 PM   #9
gn4u2c2
mustang you say .. I should bring the Firehawk and talk smack
Old 05-09-2008, 06:56 PM   #10
lowriden58
lowriden58's Avatar
hes hoping to get mid 11s this year with heads. his previous best was 12.1ish with basically stock motor with cams i miss my 03
Old 05-09-2008, 07:01 PM   #11
gn4u2c2
I have alot of suspension work and bolt ons only with 100 shot. car looks dead stock my best run was 11.02 @ 121 not bad for 128,000 and never had a valave cover off. I know I need to replace valvesprings and timing set soon but it runs so good I don't want to f-with it.
Old 05-09-2008, 07:43 PM   #12
lowriden58
lowriden58's Avatar
if ya wanna come up there your more than welcome to
