05-09-2008, 11:11 PM | #1 |
Poly Tank Fuel Filler Installed !
i am posting some pictures of how i figured to install the poly tank under the bed. i bought the basic kit wich comes with the tank and sending unit and straps. it is up to us to figure out how to install it and hook up a fuel filler system. i thought i could put a filler in the floor board over the inlet on the tank, but there didn't seem to be enough room. so i looked around and found a fuel filler door assy. online at hagenstreetrods.com . you can get the door to hinge from either side and the door can be any shape you want. i cut out an 5.25x7.75 hole in ny bed side and welded the assembly inplace. then had the local muffler shop make me a 1 1/2" pipe bent into a 45 and swelled one end to 2" to fit onto the assembly. i added a vent fitting to the tube and a fitting to the lowest corner of the box for a drain. the 1 3/8 id fuel hose i found a hoseexpress.com . and the stainless 90 ddegree 1 3/8 od mandrel elbow at classictube.com. thes fuel door assenbly comes with a fill thru cap.so there is no need to rub your knuckels on the small door opening. so cool ! i had to trim the rear x member to clear the tank and i made some brackets to keep the tank in place . as the molded in side lips are a bit on the narrow side and may slip out of place. i also tack welded the straps for a cleaner look. now the fuel system is done and i can get on with the rest of my restoration. i hope these pictures can help someone else who is thinking of how the heck does this poly tank go .
70 c10 stepside ,350v8, m-20 4 speed |
05-09-2008, 11:15 PM | #2 |
I am a Referee of life.
Re: Poly Tank Fuel Filler Installed !
Where's the pics?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
05-09-2008, 11:34 PM | #3 |
i was having trouble uploading pictures.
05-09-2008, 11:59 PM | #4 |
a motorcycle jack works great for holding up the tank
05-10-2008, 12:06 AM | #5 |
Nice install. Going to save this for when I need to do this.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
05-10-2008, 03:50 AM | #6 |
Don't forget to drop your tank back down & confirm you have a 90 ohm float it will be stamped if it is. I suspect mine isn't & heard of one other that wasn't too. Otherwise your stock fuel gage will only show 1/4 tank @ full if it has a 30 ohm.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
05-10-2008, 05:06 AM | #7 |
Nice Install, I'm doing the behind the marker light install, I'll post pics when I'm done.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
05-10-2008, 05:22 AM | #8 |
Tot Roddin'
That turned out great! Nice work!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-10-2008, 05:31 AM | #9 |
VA72C10
Did i miss where you got the poly tank and the sending unit?
05-10-2008, 07:21 AM | #10 |
Life, Be In It.....
We did the same thing to my stepside. Another member cut up a blazer fill tube to make a filler neck for their truck (link below). We are working on a blazer fill tube conversion for mine. I will post some pictures when it is done.
Nice job. I like the exhaust to idea. I came up with another solution so I could use 1 1/2 inch marine tube. http://67-72chevytrucks.com/vboard/s...d.php?t=269994
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
05-10-2008, 11:05 AM | #11 |
i got if off ebay, i think brothers sells the same kit also.
