Old 05-10-2008, 12:28 AM   #1
rscam
dummy/fake side marker lights?
I am probably the last person to know this but. I put may markers in my 69 GMC and can't find a harness for the front or rear. I looked at a wiring diagram and it shows a separate harness from the main one under the hood that goes to the bulk head. So I said I will just go to the junkyard and find one on a truck. I found a 68 and looked at the back of the light because I couldn'y find the harness on that truck either. I figured I could start at the light and go backwark till I saw where it went thru the firewall. But the light has no bulb or no hole for a buld. So they are fake. Just reflectors. Would mine have had fake ones also?
rscam is offline   Reply With Quote
Old 05-10-2008, 12:35 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: dummy/fake side marker lights?
Maybe, both my old '72 and my current '69 just had the "fake" markers...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-10-2008, 01:17 AM   #3
68caliRat
Need a bigger hammer..
Mine had the fake markers too. not even a hint of the harness for them.
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 05-10-2008, 01:40 AM   #4
El Jay
Gone to greener pastures
When I bought my '69, the PO had taken the reflectors off.
A friend of mine noticed the "empty" spaces and donated a set of marker lenses.
It now looks like it has markers, even though it don't.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-10-2008, 01:54 AM   #5
tcb-1
Nothing to see here.....
tcb-1's Avatar
'69's were not required by law to have functional marker lights..... I believe 70 and up were required. However, you can splice into front and rear blinker harness and install a two wire light socket. done and done.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-10-2008, 03:56 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
68 and 69 would be optional on pickups cab/chassis with daul rear wheels were required toahve them.
in 70 they were required.
Old 05-10-2008, 05:22 AM   #7
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
My 69 front markers wern't wired up, but the rear are. Wierd
But there is a gromit on the fire wall for the front markers that tie into the headlight switch. Search for a wiring diagram and it'll show you exactly where it hooks up. There is a connector with no wire on the plug of the head light switch for the front marker.
I think the rear are tied into the brake lights. I havn't made it to the rear on me rebuild yet, so i'm not sure.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-10-2008, 05:53 AM   #8
Longhorn Man
On all models wired with markers, the rear are on the parking lamp circuit... brown wire.
Up front, some were wired the same as the rear, others were wired to blink with the directionals
Old 05-10-2008, 10:50 PM   #9
bigblockV6
I made the dummy side marker light functional on my 68. There is a spot on inside where you can punch a hole through and stick in light socket. I spliced the front side marker wiring to the parlamps and grounded them to the turn signal that way yoou get a blinking side marker light when applying the turn signal switch just like the factory does. The rear splice into the tailamps.
bigblockV6 is offline   Reply With Quote
Old 05-11-2008, 03:46 PM   #10
68jimmy
68jimmy's Avatar
This is what I did with my 68 as well when I added functional markers. Great upgrade!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
