05-10-2008, 02:55 AM | #1 |
Active Member
My 68 1/2 ton GMC has 8 leafs. Is this right?
About 15 yrs ago a friend of mine removed some springs from my 68 half ton short bed GMC to lower it for me. He removed 2 springs from the bottom on each side and left 6. Now I'm trying to put it back the way it used to be and not sure if I have it right.
Is 8 springs on each side correct? The springs are the 2 1/4" width. Second, do the springs go shortest on bottom longest on top? On my truck the shortest one (about 12" long is on the very top). Not sure if he did that. And last, the distance from the center of the spring to the ends is not equal. Does the longer half go to the rear??? Any help appreciated... Disregard oil on the wheel. I replaced a leaking brake cylinder. |
05-10-2008, 05:46 AM | #2 |
Re: My 68 1/2 ton GMC has 8 leafs. Is this right?
it appears that someone has added some leaves to that spring pack. a couple of the thicker bottom springs.i have a '72 gmc 1/2 ton frame and it only has 5 springs. my '68 gmc 3/4 ton beater has 7 or 8 springs. the springs should be stacked shortest on bottom to the longest on top.hope this helps.
05-10-2008, 04:26 PM | #3 |
Active Member
Thanx, lilred67... I guess that the short piece on top should go on the very bottom. I'm think my buddy placed it on top to assist in the lowering.
I may just look around for some lighter springs or leave the extra ones off since I won't be using it for heavy hauling... |
09-08-2008, 10:32 AM | #4 |
My truck came stock with 9 leafs. I had a new set made because the 2 main leafs were broke. I was told only 10% of the 68 GMCs made are leaf springs.
09-08-2008, 10:35 AM | #5 |
I just noticed the U bolts are missing. Do you have them on now?
09-08-2008, 01:38 PM | #6 |
Active Member
Yeah. I was experimenting with removing some of the springs to lower it a couple of inches when I took the picture...
09-08-2008, 04:04 PM | #7 |
its all about the +6 inches
who told you that 10% of the GMC trucks had leafs?
GM didn't keep very good records back then, but considering GMC had a lot of trucks sold as work trucks, and the fact that in 68, the leafs were base equipment on ALL there truck models.... your source is probably mistaken. Add that to the fact that all the GMC records were lost... and I say someone was pullin numbers outta his dana. |
09-08-2008, 04:38 PM | #8 |
WOMP WOMP WOOOOMMMMMMP
RN U OVR |
09-08-2008, 04:51 PM | #9 |
http://67-72chevytrucks.com/vboard/c...ct=2277&cat=12
check my for sale ad; 7 mains and 3 overlaods!!!!, shortest to longest; completely factory.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro Last edited by 67mater; 09-08-2008 at 04:52 PM. |
09-08-2008, 06:36 PM | #10 |
Roadtrip!
I don't think i have ever seen a 68 gmc without leaf springs. I think one of mine has 7 on one side, and 8 on the other. Also a 1/2 ton. I would have to look at my other to see...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-08-2008, 08:06 PM | #11 |
Truck and auto performance nut
my bare '68 GMC 1/2 ton chassis has 8 leafs...but they're coming off to make room for a 4 link.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
09-08-2008, 09:40 PM | #12 |
My 67 1/2 GMC has 8 on it. How much drop did you get out of the removal?
09-08-2008, 10:41 PM | #13 |
Active Member
I took the bottom three and put the shortest one on the top of my 68 and I believe it gave me about a 2 to 2 1/2 inch drop. I'm thinking of getting some shackles to drop it another 2 inches.
The reason I'm doing it is that the front coils were cut 2 inches and I wanted to level the truck. It just sat too high up before. Last edited by 68gmsee; 09-08-2008 at 10:42 PM. |
