Old 05-10-2008, 05:00 AM   #1
JCA1972
JCA1972's Avatar
Differential ?? for a 71 C-10
Ok I consider myself a pretty good shade tree mechanic but I have never changed out the oil from a differential, I need to change out the oil in my 71 C-10, can someone please give me some advice on how to change it out and how to re fill it.
Thanks.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 05-10-2008, 06:10 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Differential ?? for a 71 C-10
place shallow pan under diff
loosen all bolts on cover, while not removing them. Start at the bottom and work your way to the top
insert screwdriver or rigid putty knife inbetween cover and diff
cuss and wipe smelly oil off of screwdriver/scraper and hand
Once it is done barfing the offending odor/oil, remove bolts and cover.
Scrape oil soaked gasket off diff and cover
wipe out the bottom of the diff with a rag *NOT WITH YOUR FINGERS* there may be sharp metal in there.
install gasket, or real good sealant (I recomend no gasket, and use The Right Stuff sealant) on cover, let sealant tack up good if you went that route
Install cover, remembering the bolt in the one O'clock position gets the bracket with the brake line in it.
On the front side of the diff, passenger side towards the center, just below the webbing that is 1/2 way up, chissel through the caked on crap, and you'll see a pipe plug with a 3/8 inch square recessed area. Put a 3/8 inch drive 6 or so inch extention in there, and remove the plug.
Fill with desired gear oil. 80/90 conventional, or the prefered, but expensive synthetic 75/140 untill it dribbles out the fill plug.
replace plug and clean up your mess.
Old 05-10-2008, 06:25 AM   #3
chrislehr
Engine n00b
chrislehr's Avatar
Thanks Longhorn - I need to suck it up and do this sometime VERY soon. Recommended place to get the sealant? Any ole Vatozone?
chrislehr is offline   Reply With Quote
Old 05-10-2008, 01:15 PM   #4
Longhorn Man
I dunno if they would have The Right Stuff... I get 99% of my stuff from NAPA. It's real easy to get real lazy... they'll deliver it to me and place it on my tool box.
Old 05-10-2008, 04:17 PM   #5
JCA1972
JCA1972's Avatar
Thanks Mr Longhorn Man, thats just what I needed, is that little hose on top of the differential a vent? Mine is plugged. I'll have to replace it.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 05-10-2008, 04:54 PM   #6
steelhorse
steelhorse's Avatar
Yes it is a vent.It should be a hose with a little "vent cap"on it.
steelhorse is offline   Reply With Quote
Old 05-10-2008, 06:19 PM   #7
whatnow123
whatnow123's Avatar
You are making it sound like there is an issue back there. Just an FYI, but if your rear is making noise, changing the oil won't fix this... ask me how I know...
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 05-11-2008, 02:21 AM   #8
chrislehr
Engine n00b
chrislehr's Avatar
lol - no mine just has a slow leak so it looks like Molly wet herself.
Old 05-10-2008, 11:54 PM   #9
Longhorn Man
I was thinking that was the brake line T fitting... it's been a while since I did this.
