![]() Join Date: Feb 2007
Primer Over Paint
Does Anybody Have An Idea On How To Get Primer Off Of Paint Without Sanding I Assume It Was Primed To Cover Rust And Or Patina Which I Think I Like I Also Need A Dark Green Dog House If Any Body Knows Of One
![]() Join Date: Nov 2003
Re: Primer Over Paint
Why don't you want to sand? I think that would be easier to control then a chemical remover.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Gettin By on Gettin By
hmm.. Most primer over paint will flake off with a car wash sprayer. Might try that. Or carb cleaner. That takes off most anything.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
I DONT WANT TO SAND OFF GREEN UNDER IT WANT TO TRY TO PRESERVE THE PATINA UNDERNEATH AND CARB CLEANER DIDNT DO ANY THING NOR DID PAINT THINNER THANKS FOR INPUT
hmmm... brake fluid?? that'll strip anything loose.
thats most of the quick ways, aside from wet sanding by hand untill the green shows through, you pretty much stuck imo.
I still think sanding is the way to go. Really fine sand paper, and stop and clean it off every couple of minutes to make sure you haven't gone to deep.
