Old 05-10-2008, 07:56 AM   #1
69face
69face's Avatar
flip kit gone way wrong!!! need help!!
i flipped a 1976 chevy 1/2 ton truck over the leafs and i can't figure out why the drivers side shock won't stop bottoming out. i used the stock shocks at first and then i when and measured and got a shorter shock. the passenger side is just fine. i think it's because of the way the original shock locations are. i have the 1/2 ton 5 leaf pac i believe. will drop shocks work or will i end up in the same spot? please give me feedback toward a remedy? thanks in advance. still love my chevy even though it rides like a brick.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 05-10-2008, 01:19 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: flip kit gone way wrong!!! need help!!
Please post a picture to help us understand. Also,... did you remove the factory bumpstop and metal frame bracket?
Keith
Convert to disc brakes.
Old 05-10-2008, 04:36 PM   #3
SCOTI
SCOTI's Avatar
Pics would help. Did your flip kit come w/some shock extenders?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-11-2008, 05:48 AM   #4
69face
69face's Avatar
i got the shock extenders today and will be removing the bump stops and puttinh the djm bump stops in. i think those are the major issue( or at least i hope, because i've never heard of any problems like this one. i'll post pics before and after i install( hopefully after all is cured)
I'M SO SO CAL!
Old 05-12-2008, 02:11 AM   #5
69face
69face's Avatar
I'M SO SO CAL!
Old 05-12-2008, 02:13 AM   #6
69face
69face's Avatar
I'M SO SO CAL!
Old 05-12-2008, 02:26 AM   #7
69face
69face's Avatar
I'M SO SO CAL!
Old 05-12-2008, 02:28 AM   #8
69face
69face's Avatar
I'M SO SO CAL!
Old 05-12-2008, 02:31 AM   #9
69face
69face's Avatar
this is all i got done today and it still rides a bit rough. i think it may be the way i set the pinion angle. i think it's too negatve which pushes the drivers side shock up and the passenger down. i guess i can find some pinion shims or make some to correct it. waiting for 2 inch drop spindles to complete my 5/7 drop
I'M SO SO CAL!
Old 05-12-2008, 11:48 AM   #10
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Nice work man,,,,
How well did you "enjoy" removing those OE bump stops?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 05-13-2008, 07:01 AM   #11
69face
69face's Avatar
Originally Posted by Mr79C10 View Post
Nice work man,,,,
it was easy. i didnt have a problem at all. i just heated the rivets with a torch until they were cherry red and then used a impact chisel to knock them off. after that i used an impact punch to knock them out. it took less than 5 minutes per bump stop. organization makes it go smoothly. they came off so clean
I'M SO SO CAL!
Old 05-16-2008, 12:40 AM   #12
69face
69face's Avatar
i guess i wont be waiting on 2 inch spindles since they don't make them. why dont they make them? i guess i have to go 2.5 spindles. 1/2 inch lower isn't going to hurt anything but the ants!
I'M SO SO CAL!
Old 05-16-2008, 12:51 AM   #13
scotts62
One day...
scotts62's Avatar
Nope slam it!! Looks good man
Scott
93 crew cab build
Project 62
