Removal of rear engine cross member?
I was wondering if anyone would know if they make a urethane mount for the rear engine mounts? Also I was thinking of possibly removing the rear engine cross member, If anyone would know if thats a bad idea... (Its for a 67 2wd swb ,4speed muncie-383 stroker) Thanks to anyone who helps!!
Re: Removal of rear engine cross member?
How will you support the rear of the engine without the crossmember?
trailers are for boats |
I am a Referee of life.
Lots of people remove the crossmember when swapping to an auto.They then install a tranny crossmember.If you do remove it you will need to install a tranny crossmember to support the tranny and rear of the engine.Look at any 60's car with the tranny crossmember and you will see that it supports the rear of the engine and the tranny.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
