Old 05-11-2008, 12:07 AM   #1
Rigo's 70 C10
Ride quality with air bags?????
I want to bag my 70 C10, however i recently heard someone at a car show say that trucks on bags had a horrible ride. He works for Scoggin Dickey as a mechanic and gets to test drive many vehicles.
Is this guy right about the ride being horrible (bouncy)?
Please comment! I dont want to sacrifice ride quality for looks.
Rigo's 70 C10 is offline   Reply With Quote
Old 05-11-2008, 12:24 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Ride quality with air bags?????
workin at a dealer, there are very few cars he would be driving with bags... a modified one or two, and then the caddys with bags, and expiditions, and lincolns....
I think that guy is full of something or only driven an improper assembled one.
Bags have been put in luxo cars since the 70's, and they give the best ride of ANY type suspention if done right.
Old 05-11-2008, 12:51 AM   #3
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i'll chime in here. when i got my truck, it had cut coils and was super bouncy going down the road.
i bagged it in all 4 corners, and the ride is MUCH better. the only time it's bouncy is if the bags are nearly empty, or full extended. for normal driving, it's great
IvelDesigns is offline   Reply With Quote
Old 05-11-2008, 01:12 AM   #4
Shane
Shane's Avatar
No to be a smarty, but it is like riding on air.
Shane is offline   Reply With Quote
Old 05-11-2008, 01:48 AM   #5
jimmydean
jimmydean's Avatar
Good shocks and proper ride inflation make for an awesome ride. Good shocks will take the bounce out and having just the right amount of air.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-11-2008, 01:50 AM   #6
Number98
Prestige Worldwide
Number98's Avatar
Number98 is offline   Reply With Quote
Old 05-11-2008, 05:09 AM   #7
It depends on how much air you`re running.I do know that Greyhound buses and moving vans use air suspension solely for the "better" ride.
Old 05-11-2008, 08:12 AM   #8
Rigo's 70 C10
I will bag it and let it lay low! I was sure that poor soul had no idea what he was talking about.
Thanks for the insight.
Old 05-11-2008, 08:15 AM   #9
hotrodhomi
hotrodhomi's Avatar
smooth like butter.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 05-11-2008, 08:32 PM   #10
MrGoodpliers
MrGoodpliers's Avatar
I have bags on the rear of my suburban and have found that the ride quality is better when it's loaded or towing and the pressures are higher.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 05-11-2008, 09:10 PM   #11
bowtieboy93
bowtieboy93's Avatar
they are great
But like others have said
higher or lower pressures will cause some bounce but if you fill it at normal pressure you will be fine
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 05-12-2008, 02:26 AM   #12
ostncoln
ostncoln's Avatar
here is an example of when airbags dont ride so well
zero psi you can really feel it in your back
other than that they are smooth , better than stock in most cases
1971 C-10 Project
350/400
5/7 drop
My Slow Build Thread
ostncoln is offline   Reply With Quote
Old 05-12-2008, 05:48 AM   #13
kamikazekyle05
kamikazekyle05's Avatar
Not to hijack, but what psi do most of yall run?
kamikazekyle05 is offline   Reply With Quote
Old 05-12-2008, 07:36 AM   #14
Rigo's 70 C10
Can i get some expamples of drops? I want to get mine low! Will the kit from air ride technologies work? They sell the kit with the cnotch and crossmember with bags. CPP also has one, any thoughts on either. They are about 1600.00. Will it give me enough rear drop? If it wont give me the drop i want, who makes a good notch? I am guessing it is not going to be a bolt on.
Thanks in advance for your words of wisdom!
Old 05-12-2008, 07:55 AM   #15
HoupPhotography
How low do you want it to be? There are also other factors to consider when your talkin "low", what size wheel & tire combo are you going to run? Mine is on 20's and is as low as it will go without relocating the hood hinge mounts and doing some fab work to the inner fenders, with the steelies and fat whites it will sit about 2.5 inches lower.
Just to get to this point the inner fender wells on the front and back had to be removed and if you have a decent size wheel and tire combo, you'll have problems getting the hood to fit properly (without the wheel hitting it)
It also depends on the look your after, if it's the rat rod style then it will be much easier than a "boyd" type of build.
Here are some photos of mine......
This is a lightened photo of the front end so you can see the minimal clearance...
This is good photo to show how it sits when it's deflated, the front sits up a little higher...
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-12-2008, 09:07 AM   #16
IvelDesigns
i personally wouldn't go with a kit. i got everything i needed from ***************** . I would suggest a c-notch for a decent, drivable drop in the rear, and drop spindles up front. as houp said, a fender mod will be needed to get real low up front. IMO, doing the frizzle fry fender mod is a great way to go to get an extra inch clearance w/o moving your hood hinge. again, a drivable height.
i highly suggest you build your truck so that it can be driven with no air if there is a need. not at highway speeds, but "i just need to get home" speeds. it's more of a safety factor than anything.
if you want to go extreem and lay frame, you have your work cut out for you. plan on a step notch, if not a complete rear suspension setup. the drop member from porterbuilt will help a ton up front, but there are other, cheaper, but time consuming ways to get real low up front.
what are your fab skills? do you feel comfortable cutting the back half of your frame off and building it new? do you understand suspension geometry? if not, i would suggest you go the route i initally suggested. c-notch and drop spindles. or, if you're up to the task, jump in head first and learn as you go. the suspension forums will answer just about any question you have no matter how complicated of a build you have.
all of this is said assuming you have a coil setup, not leaf.
oh, and post lots of pics during your build!!
Old 05-12-2008, 02:19 PM   #17
70GMCer
70GMCer's Avatar
Bags go back further than 70s. My 59 Caddie had factory bagged shocks. They were filled with freon.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-12-2008, 07:12 PM   #18
Rigo's 70 C10
What kind of notch would you suggest? My truck has leaf springs and i am in the process of finding a coil set up so i can convert it. That is why i was considering the cpp or air ride system, it comes with the crossmember, triailing arms, cnotch, panhard bar and bags. I am not going to go with the rat rod look, i am probably going to go solid black with all chrome, or pewter with chrome. I love the stance on HoupPhotographys truck. What drop is that? Ball park, that is what i am looking for. My doors dont need to lay on the ground. I have wanted a short bed 67-72 truck since i was 12. I am now 34 and finally found one. this is my dream ride so you can understand why i have so many questions. It has to be perfect!
You guys are truly masters of your craft.
Old 05-12-2008, 07:37 PM   #19
HoupPhotography
I returned your pm... I dug up everything I could, but can't remember the specific drop #.
Old 05-12-2008, 08:08 PM   #20
hotrodhomi
hotrodhomi's Avatar
I would look into a triangulated four link.
'66 impala ht
Old 05-13-2008, 03:30 AM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Can I say... like a Caddy!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
