Living In The Past
Which 3M glue?
There are so many different ones. Which one is the best for headliner install and where would one get it? I went to the auto paint store, figured they would have it and know which one but they were clueless. Thanks..
Re: Which 3M glue?
Higher the number the higher the sticky IIRC. 75 is what I have used for stereo crap, but I think you can get 90.
<edit> Super 77 is what I use.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 05-11-2008 at 01:46 AM. |
Parts and more parts
Re: Which 3M glue?
Are you talking about the foam backed headliner material install? If so, then you can get away with a quart or two of just plain old Contact Cement and a cheapo spray gun from Wally Mart. Set the settings on the gun to spray a very thick trace and spray both the foam backing and the surface that you are mounting it to. let set for a few minutes and then stick material to surface. DO NOT OVERSPRAY or glue will soak through the material. It will come out looking like a buch of ribbons and not a spray paint coating. I have done it many times. Clean the gun with a lacquer thinner.
its all about the +6 inches
Re: Which 3M glue?
if you are talking about the vinal covered cardboard stock headliner, the factory used a thick glue, I just used a 1/2 tube of liquid nails in a caulking gun.
Living In The Past
Re: Which 3M glue?
yes , stock factory type... thanks..
![]() Join Date: Oct 2005
Re: Which 3M glue?
Liquid Nails for me too.........stuck REAL good!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Re: Which 3M glue?
I used the 3m spray adhesive shown above. I never considered liquid nail, that stuff would definitely do the job.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
67-72 Addict!
Re: Which 3M glue?
I like to use GE Silicone II in a caulk tube. It's flexable, water tight and can be removed cleanly if you decide to later on. It goes on neat and easy too!. Just make sure to rub the ceiling down with alcohol really well and clean the back of the headliner also. I use a spare set of stock door panels wedged between the seat with a folded towel wrapped over each end of the edge of the panel that is up against the headliner to prevent marring the vinyl.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
