05-11-2008, 08:21 AM | #1 |
PITbut
How do you tell when a rebuild is needed.
How do you tell when a transmission needs to be rebuilt?? I have a TH400 that im puttin in my truck. The vehicle i took it out of the tranny felt fine. I do need a different torque converter on it, (new cam on new motor) but what do i check inside the trans>???
i do have a book on its way on how to rebuild a TH400, but i was hoping i could get some advice.. Impatient on the book. ahah |
05-11-2008, 08:42 AM | #2 |
Re: How do you tell when a rebuild is needed.
It depends on what you want from the trans. If you want perfection, rebuild it. If a minor leak is acceptable run it till there is a problem then rebuild.
05-11-2008, 08:58 AM | #3 |
Since you have a new motor, I would rebuild it, IMO, if the thanny leaks that is a problem. Take a little extra time to make sure you don't have any leaks, less headache, more drive time & less down time. If I'm going to do something, I try to do it once and be done.... but it doesn't always work that way....
R.I.P. Scott Kalitta
05-11-2008, 03:36 PM | #4 |
Just had mine rebuilt....first sign is when the seals go and it's hard to engage when cold. Other signs are slippage in one gear or another or slow shifts.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
05-11-2008, 05:34 PM | #5 |
PITbut
I dont have any of those signs.... Im leaning towards the rebuild... Since im putting in a new torque converter and shift kit, i figured rebuilding it wouldnt hurt.
05-11-2008, 06:26 PM | #6 |
resto body guy
i think a trans rebuild is cheap insurance! that way you don't have to pull it back out 3 months down the road!
05-11-2008, 08:52 PM | #7 |
Just one more reason to rebuild it.....
05-11-2008, 09:06 PM | #8 |
Saving 1 truck at a time!
If it's out and you are rebuilding the engine...REBUILD IT! Especially if you are doing an engine upgrade, changing the TC and adding a shift kit. Gitterdun...LOL! You want to forget about it and not have to worry about it when you use the loud pedal!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
05-12-2008, 08:17 AM | #9 |
Rice Killing 101
rebuild it cuz so far ive had to pull my friends 727 torqueflight out 5 times now we're pros at it so get it out of the way so much easier than pullin it out every weekend
distrubin the peace since i got the thing and broke the origianl radio on 95.5 classic rock Ride: 1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi puttin in a 496 rebuilding trans need to rebuild diff :| need to start takin pics and start a project thread |
