Old 11-04-2002, 11:03 PM   #1
Leinie
Steering problem
I've been having an intermittant steering problem. Sometimes I'll take a corner from a stop,( Either direction) when I return the wheel to go straight, the truck will lurch to the opposite direction as if a ghost yanked the wheel a 1/4 turn.
It's strange, I'll start heading straight and then a quick jolt, then straight again.
I just had new tires put on ( coincidently right before this started)
but can't find any evidence of tampering- but they tried real hard to sell me an alignment I knew was not neccessary.
I also have 2- Rancho steering stabilizers on the truck- Oh= It's a 72 Blazer 4X4
If anyone can point me in the right direction I'd appreciate it
Leinie is offline   Reply With Quote
Old 11-05-2002, 12:16 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
*points at the tie rod ends*
That's the first place I'd look.
Old 11-05-2002, 12:20 AM   #3
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
It sounds like you have a frozen axle u joint, lift your front tires off the ground and crank your wheels to the right, spin your tires around on each side and see if there is any resistance, crank your wheels to the left and try spinning them again. Also try this with your hubs locked in, I have seen axle u joints freeze solid in no time once they take on water.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 11-05-2002, 12:25 AM   #4
Piston
Piston's Avatar
It's also a VERY good idea to shake the front end down while your checking those. Sounds like parts are binding then popping loose, this is about to get dangerous.
Piston is offline   Reply With Quote
Old 11-05-2002, 08:40 AM   #5
Leinie
Thanks for giving me some places to start looking. It's been making me real nervous. It's my daily driver, but luckily I only drive a few miles through town ( 30 mph limit ). I used to take it out of town just to get it warmed up in the morning but not anymore- until I get it fixed.
